user:tim:start [2014/11/06 15:13] tim |
user:tim:start [2017/04/05 00:38] (current) |
* LMN | * LMN | ||
+ | * draw / price in emachineshop | ||
* solar panel gas-sprung hatch w/ deep cycle marine batter, $20 charge controller, and laptop inverter w/ USB | * solar panel gas-sprung hatch w/ deep cycle marine batter, $20 charge controller, and laptop inverter w/ USB | ||
* http://www.harborfreight.com/870-lb-capacity-40-inch-x-49-inch-heavy-duty-utility-trailer-with-8-inch-wheels-and-tires-42708.html | * http://www.harborfreight.com/870-lb-capacity-40-inch-x-49-inch-heavy-duty-utility-trailer-with-8-inch-wheels-and-tires-42708.html | ||
Line 66: | Line 68: | ||
Line 98: | Line 101: | ||
Line 115: | Line 113: | ||
*BEACON | *BEACON | ||
Line 130: | Line 129: | ||
Line 139: | Line 137: | ||
Line 168: | Line 166: | ||
Line 179: | Line 175: | ||
* mUVe3D | * mUVe3D | ||
* solar | * solar | ||
Line 201: | Line 201: | ||
Line 256: | Line 257: | ||
====== board goals ====== | ====== board goals ====== | ||
- | * build asset maps for LMN - committe | + | * build asset maps for LMN - committee |
- | * include community members on board committees | + | * identify asset goals, and a plan to fill them |
+ | * who do we need (what skills, resources?) | ||
- | * annual nonprofitnetwork board training / reflection / reevaluation | + | * continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation |
+ | * establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / read aloud once a year at a meeting | ||
+ | * mission: education and access | ||
