user:tim:start [2014/11/14 17:56] tim |
user:tim:start [2014/12/04 23:47] tim |
Line 68: | Line 68: | ||
Line 100: | Line 101: | ||
Line 185: | Line 181: | ||
* honeywell RTH2300B1012 thermostat [[https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2326ES.pdf|manual]] | * honeywell RTH2300B1012 thermostat [[https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2326ES.pdf|manual]] | ||
* improve dryer efficiency: http://www.alkeng.com/AL/dryer | * improve dryer efficiency: http://www.alkeng.com/AL/dryer |
