user:tim:start [2014/11/06 18:17] tim |
user:tim:start [2014/11/20 23:26] tim |
* LMN | * LMN | ||
Line 99: | Line 100: | ||
Line 181: | Line 177: | ||
* mUVe3D | * mUVe3D | ||
* solar | * solar | ||
Line 203: | Line 200: | ||
* http://www.newegg.com/Product/Product.aspx?Item=N82E16811345016 for nvidia jetson | * http://www.newegg.com/Product/Product.aspx?Item=N82E16811345016 for nvidia jetson |
