user:tim:start [2014/11/06 16:48] tim |
user:tim:start [2014/11/21 00:37] tim |
* LMN | * LMN | ||
Line 99: | Line 100: | ||
Line 116: | Line 112: | ||
*BEACON | *BEACON | ||
Line 180: | Line 177: | ||
* mUVe3D | * mUVe3D | ||
* solar | * solar | ||
Line 202: | Line 203: | ||
Line 267: | Line 269: | ||
* continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation | * continual orientation - annual nonprofitnetwork board training, org reflection / reevaluation | ||
* establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / read aloud once a year at a meeting | * establish whistle blower / COI policy allowing for nomination of an outsider compliance officer - create COI disclosure form / read aloud once a year at a meeting | ||
- | * mission: skills and access | + | * mission: education and access |
