user:tim:gridbeam_drill_press [2014/11/18 15:10] tim |
user:tim:gridbeam_drill_press [2014/11/19 18:22] tim |
- | ===BOM=== | + | based on: http://www.openbuilds.com/builds/mini-v-linear-actuator-build.48/ |
- | * 2x http://openbuildspartstore.com/688z-ball-bearing-8x16x5/ | + | |
- | * 4x http://openbuildspartstore.com/openbuilds-solid-v-wheel-kit/ | + | |
- | Or (up to 3657mm 12 feet) | + | ===Openbuilds BOM=== |
- | * $61.14 http://www.mcmaster.com/#perforated-structural-framing-tubing | + | * $10 2x http://openbuildspartstore.com/v-slot-actuator-end-mount/ |
+ | * $13 4x http://openbuildspartstore.com/mini-v-wheel-kit/ | ||
+ | * $6 4x http://openbuildspartstore.com/universal-l-brackets/ | ||
+ | * $18 1x http://openbuildspartstore.com/nema-17-stepper-motor/ | ||
+ | * $7 1x http://openbuildspartstore.com/gt2-2mm-aluminum-timing-pulley-30/ | ||
+ | * $5 1x http://openbuildspartstore.com/smooth-idler-pulley-kit/ | ||
+ | * $39 3x http://openbuildspartstore.com/v-slot-20-x-40mm/ | ||
+ | * $9 1x http://openbuildspartstore.com/mini-v-plate/ | ||
+ | * $2 2x http://openbuildspartstore.com/belt-crimp-clamp/ | ||
+ | * $1 4x 30mm http://openbuildspartstore.com/m3-cap-head-screws/ | ||
+ | * $62.50 (25ft) http://openbuildspartstore.com/gt2-2mm-timing-belt/ | ||
+ | * $3 4x http://openbuildspartstore.com/double-tee-nut/ | ||
+ | * $2 6mm http://openbuildspartstore.com/socket-head-screws-m3-25-pack/ | ||
- | Or (up to 1740mm - 5.7 feet) | + | ===Gridbeam BOM=== |
- | * http://us.misumi-ec.com/vona2/detail/110300071070/?Brand=MSM1 | + | * aluminum 1.5" gridbeam |
- | * http://us.misumi-ec.com/vona2/detail/110300070820/?Inch=0 | + | * 1/8 inch x 2 inch perforated aluminum plate |
+ | * 90 deg angle stepper motor mount | ||
+ | * 90 deg angle bearing block | ||
+ | * 1/8 inch aluminum plate carriage | ||
+ | * 1/8 inch apeture rollers | ||
+ | * nuts, bolts, spacers for rollers |
