principal_permitted_uses_policy [2017/04/05 00:38] |
principal_permitted_uses_policy [2017/04/05 00:38] (current) |
+ | ====== Facilities Principal permitted uses policy ====== | ||
+ | :NOTE: This is a preliminary work in progress. | ||
+ | The intent of LMN is to facilitate community effort in making non-commodity items. And as such common activities will include occasional use of small to light industrial equipment. Ranging from hand tools, to table mounted tools and floor mounted tools. | ||
+ | Operation of the equipment, material storage and use will comply to local laws. As not to inconvenience the immediate community. | ||
+ | All equipment will be operated within the facilities premise. | ||
+ | No equipment will be operated outside of the building premise after 9pm. | ||
+ | The facility shall prohibit the prolonged making, creation or maintenance of such excessive, unnecessary, unnatural or unusually loud noises and odors. | ||
+ | Only commonly available material (chemicals) and volumes of such, not requiring permits shall be used or housed on premise. | ||
+ | The facility may host events and activities, which must comply with local laws, as not to inconvenience the immediate community. | ||
+ | The facility may host experimental, research or development laboratory may be permitted in an F or F-1 Commercial District. | ||
+ | All activities shall be conducted within an enclosed structure. | ||
+ | Any other use which, by the decision of the Planning Board, is similar to the principally permitted uses set forth in this section; | ||
+ | A private club, fraternal organization or lodge hall; | ||
