meetings:20151019_minutes [2017/04/05 00:38] |
meetings:20151019_minutes [2017/04/05 00:38] (current) |
+ | Treasurer's Report - | ||
+ | Bank Balance: $15736.94 | ||
+ | President Report : Deferred to other agenda items | ||
+ | Space Report: | ||
+ | New door code | ||
+ | Possible changing of the layout | ||
+ | Door has a crash bar but does have a mortise latch. | ||
+ | Brian will look at motise latches. | ||
+ | Al is rekeying for a master key setup. | ||
+ | Still water on the floor under the machine shop, Al knows it on his list. | ||
+ | Damaged window panes have been replaced. | ||
+ | One window in the common area remains to be replaced. | ||
+ | Waiting on confirmation from Al that permits have been closed. | ||
+ | Jerry and Brian recapped the Makerspace bootcamp @ Makerworks. | ||
+ | Brian showed the Trello board and added everyone to it. | ||
+ | Laser cutter SOP | ||
+ | Brian has put together the initial version of the Laser SOP | ||
+ | Ready to teach a class as soon as someone can walk through a test run of the class. | ||
+ | Rose suggested that changing the color on the front could be a good way to indicate a revision. | ||
+ | LMN Visioning | ||
+ | Brian shared the general process for how to vision, what our process will be for drafting an LMN vision. | ||
+ | Everyone will /draft/ their personal vision for LMN and share it by Monday, October 26th | ||
+ | We'll discuss and share commonalities on each other's vision at the next board work session: Nov 2nd. | ||
+ | B&N MMF: | ||
+ | Need Flyers and Pamplets | ||
+ | Need demos / or things. | ||
+ | Dinosaur cut. | ||
+ | Need more things to leave there we don't worry about leaving. | ||
+ | Makey Makey Day: | ||
+ | Robot pumpkin LED makey. | ||
+ | This Thursday, 4:30 - 6:30 | ||
+ | Carl is working on a Makey Makey banana project. | ||
