lockout_tagout:start [2015/06/26 15:32] zimmer62 |
lockout_tagout:start [2017/04/05 00:38] (current) |
Line 9: | Line 9: | ||
* [[https://en.wikipedia.org/wiki/Lockout-tagout|wikipedia entry about lockout tagout]] | * [[https://en.wikipedia.org/wiki/Lockout-tagout|wikipedia entry about lockout tagout]] | ||
- | ==== Resources ==== | + | ===== Resources ===== |
* {{:lockout_tagout:lockou_tagout_1_sheet.pdf|Printable PDF for lockout tags}} | * {{:lockout_tagout:lockou_tagout_1_sheet.pdf|Printable PDF for lockout tags}} | ||
* {{:lockout_tagout:lockou_tagout_1_sheet.ai|Adobe Illustrator for lockout tags}} | * {{:lockout_tagout:lockou_tagout_1_sheet.ai|Adobe Illustrator for lockout tags}} | ||
- | ==== To do: ==== | + | ===== IEC C13 Tagout ===== |
- | * Design an IEC C13 3D printable plug to tagout a device which accepts that kind of power cord: | + | {{:lockout_tagout:c13-sideview.jpg?150|}}{{:lockout_tagout:c13-plugside.jpg?229|}} |
- | * use the dimensions from [[http://www.mouser.com/catalog/specsheets/KC-301194.pdf|Here]] | + | * {{:lockout_tagout:c13_tagout_source_files_freecad_and_stl.zip|FreeCad and STL Source files}} |
- | * 40 Tags have been printed, however they need to be cut out and laminated | + | |
+ | ===== Example Tagout installations ===== | ||
+ | {{:lockout_tagout:image1_2_.jpg?200|}} | ||
+ | {{:lockout_tagout:image2_2_.jpg?200|}} | ||
+ | {{:lockout_tagout:image3.jpg?200|}} | ||
+ | ===== To do ===== | ||
* A box in each area that can hold tags / locks etc, sharpies, log book, and brochures. | * A box in each area that can hold tags / locks etc, sharpies, log book, and brochures. | ||
* Probably keep one log book for the space, but tags and instructions near each area. | * Probably keep one log book for the space, but tags and instructions near each area. | ||
- | * Design a brochure. | ||
* Design and implement an online wiki log book | * Design and implement an online wiki log book | ||
- | ==== Already done: ==== | + | ==== Already done ==== |
* Printed 40 tags | * Printed 40 tags | ||
+ | * 32 tags are on the chalkboard near the entrance. | ||
+ | * Joe designed an IEC C13 3D printable plug to tagout a device which accepts that kind of power cord | ||
+ | * Used the dimensions from [[http://www.mouser.com/catalog/specsheets/KC-301194.pdf|Here]] | ||
