Both sides previous revision Previous revision | |||
lockout_tagout:start [2015/07/01 03:45] zimmer62 [To do] |
lockout_tagout:start [2015/07/03 20:38] zimmer62 |
Line 12: | Line 12: | ||
* {{:lockout_tagout:lockou_tagout_1_sheet.pdf|Printable PDF for lockout tags}} | * {{:lockout_tagout:lockou_tagout_1_sheet.pdf|Printable PDF for lockout tags}} | ||
* {{:lockout_tagout:lockou_tagout_1_sheet.ai|Adobe Illustrator for lockout tags}} | * {{:lockout_tagout:lockou_tagout_1_sheet.ai|Adobe Illustrator for lockout tags}} | ||
+ | ===== IEC C13 Tagout ===== | ||
+ | {{:lockout_tagout:c13-sideview.jpg?150|}}{{:lockout_tagout:c13-plugside.jpg?229|}} | ||
+ | * {{:lockout_tagout:c13_tagout_source_files_freecad_and_stl.zip|FreeCad and STL Source files}} | ||
+ | ===== Example Tagout installations ===== | ||
+ | {{:lockout_tagout:image1_2_.jpg?200|}} | ||
+ | {{:lockout_tagout:image2_2_.jpg?200|}} | ||
+ | {{:lockout_tagout:image3.jpg?200|}} | ||
===== To do ===== | ===== To do ===== | ||
Line 22: | Line 31: | ||
==== In Progress ==== | ==== In Progress ==== | ||
* Jerry is designing a brochure. | * Jerry is designing a brochure. | ||
- | * Joe is designing an IEC C13 3D printable plug to tagout a device which accepts that kind of power cord | ||
- | * use the dimensions from [[http://www.mouser.com/catalog/specsheets/KC-301194.pdf|Here]] | ||
- | * Here are some images of the latest prototype: [[lockout_tagout:c13|C13 Tagout Plug]] | ||
==== Already done ==== | ==== Already done ==== | ||
Line 30: | Line 36: | ||
* 40 Tags have been cut out and laminated -- 8 tags were destroyed by the laminater. | * 40 Tags have been cut out and laminated -- 8 tags were destroyed by the laminater. | ||
* 32 tags are on the chalkboard near the entrance. | * 32 tags are on the chalkboard near the entrance. | ||
+ | * Joe designed an IEC C13 3D printable plug to tagout a device which accepts that kind of power cord | ||
+ | * Used the dimensions from [[http://www.mouser.com/catalog/specsheets/KC-301194.pdf|Here]] | ||
