lockout_tagout:start [2015/06/26 03:18] zimmer62 created |
lockout_tagout:start [2015/07/01 03:45] zimmer62 [To do] |
- | Draft! Please feel free to contribute! | + | {{ :lockout_tagout:lockou_tagout_1_back.jpg?100|}}{{ :lockout_tagout:lockou_tagout_1.jpg?100|}}Draft! Please feel free to contribute! |
====== Lockout / Tagout ====== | ====== Lockout / Tagout ====== | ||
Line 5: | Line 5: | ||
===== What is Lockout / Tagout ===== | ===== What is Lockout / Tagout ===== | ||
- | Lockout-tagout (LOTO) or lock and tag is a safety procedure which is used in industry and research settings to ensure that dangerous machines are properly shut off and not started up again prior to the completion of maintenance or servicing work | + | * Lockout-tagout (LOTO) or lock and tag is a safety procedure which is used in industry and research settings to ensure that dangerous machines are properly shut off and not started up again prior to the completion of maintenance or servicing work |
+ | * It can also be used to identify a machine that is out of service that would be dangerous to energize. | ||
+ | * [[https://en.wikipedia.org/wiki/Lockout-tagout|wikipedia entry about lockout tagout]] | ||
- | It can also be used to identify a machine that is out of service that would be dangerous to energize. | + | ===== Resources ===== |
+ | * {{:lockout_tagout:lockou_tagout_1_sheet.pdf|Printable PDF for lockout tags}} | ||
+ | * {{:lockout_tagout:lockou_tagout_1_sheet.ai|Adobe Illustrator for lockout tags}} | ||
+ | ===== To do ===== | ||
+ | * A box in each area that can hold tags / locks etc, sharpies, log book, and brochures. | ||
+ | * Probably keep one log book for the space, but tags and instructions near each area. | ||
+ | * Design and implement an online wiki log book | ||
+ | * Joe is designing an IEC C13 3D printable plug to tagout a device which accepts that kind of power cord | ||
+ | * use the dimensions from [[http://www.mouser.com/catalog/specsheets/KC-301194.pdf|Here]] | ||
+ | ==== Already done ==== | ||
+ | * Printed 40 tags | ||
+ | * 32 tags are on the chalkboard near the entrance. |
