lockout_tagout:start [2015/06/26 15:32] zimmer62 |
lockout_tagout:start [2015/07/01 03:44] zimmer62 |
Line 9: | Line 9: | ||
* [[https://en.wikipedia.org/wiki/Lockout-tagout|wikipedia entry about lockout tagout]] | * [[https://en.wikipedia.org/wiki/Lockout-tagout|wikipedia entry about lockout tagout]] | ||
- | ==== Resources ==== | + | ===== Resources ===== |
* {{:lockout_tagout:lockou_tagout_1_sheet.pdf|Printable PDF for lockout tags}} | * {{:lockout_tagout:lockou_tagout_1_sheet.pdf|Printable PDF for lockout tags}} | ||
* {{:lockout_tagout:lockou_tagout_1_sheet.ai|Adobe Illustrator for lockout tags}} | * {{:lockout_tagout:lockou_tagout_1_sheet.ai|Adobe Illustrator for lockout tags}} | ||
- | == To do: == | + | ===== To do ===== |
- | * Design an IEC C13 3D printable plug to tagout a device which accepts that kind of power cord: | + | |
- | * use the dimensions from [[http://www.mouser.com/catalog/specsheets/KC-301194.pdf|Here]] | + | |
- | * 40 Tags have been printed, however they need to be cut out and laminated | + | |
* A box in each area that can hold tags / locks etc, sharpies, log book, and brochures. | * A box in each area that can hold tags / locks etc, sharpies, log book, and brochures. | ||
* Probably keep one log book for the space, but tags and instructions near each area. | * Probably keep one log book for the space, but tags and instructions near each area. | ||
- | * Design a brochure. | ||
* Design and implement an online wiki log book | * Design and implement an online wiki log book | ||
+ | * Joe is designing an IEC C13 3D printable plug to tagout a device which accepts that kind of power cord | ||
+ | * use the dimensions from [[http://www.mouser.com/catalog/specsheets/KC-301194.pdf|Here]] | ||
- | == Already done: == | + | ==== Already done ==== |
* Printed 40 tags | * Printed 40 tags | ||
+ | * 32 tags are on the chalkboard near the entrance. |
