lockout_tagout:start [2015/06/26 03:19] zimmer62 |
lockout_tagout:start [2015/06/26 15:33] zimmer62 |
- | Draft! Please feel free to contribute! | + | {{ :lockout_tagout:lockou_tagout_1_back.jpg?100|}}{{ :lockout_tagout:lockou_tagout_1.jpg?100|}}Draft! Please feel free to contribute! |
====== Lockout / Tagout ====== | ====== Lockout / Tagout ====== | ||
Line 7: | Line 7: | ||
* Lockout-tagout (LOTO) or lock and tag is a safety procedure which is used in industry and research settings to ensure that dangerous machines are properly shut off and not started up again prior to the completion of maintenance or servicing work | * Lockout-tagout (LOTO) or lock and tag is a safety procedure which is used in industry and research settings to ensure that dangerous machines are properly shut off and not started up again prior to the completion of maintenance or servicing work | ||
* It can also be used to identify a machine that is out of service that would be dangerous to energize. | * It can also be used to identify a machine that is out of service that would be dangerous to energize. | ||
+ | * [[https://en.wikipedia.org/wiki/Lockout-tagout|wikipedia entry about lockout tagout]] | ||
+ | ===== Resources ===== | ||
+ | * {{:lockout_tagout:lockou_tagout_1_sheet.pdf|Printable PDF for lockout tags}} | ||
+ | * {{:lockout_tagout:lockou_tagout_1_sheet.ai|Adobe Illustrator for lockout tags}} | ||
+ | ===== To do ===== | ||
+ | * Design an IEC C13 3D printable plug to tagout a device which accepts that kind of power cord: | ||
+ | * use the dimensions from [[http://www.mouser.com/catalog/specsheets/KC-301194.pdf|Here]] | ||
+ | * 40 Tags have been printed, however they need to be cut out and laminated | ||
+ | * A box in each area that can hold tags / locks etc, sharpies, log book, and brochures. | ||
+ | * Probably keep one log book for the space, but tags and instructions near each area. | ||
+ | * Design a brochure. | ||
+ | * Design and implement an online wiki log book | ||
+ | ==== Already done ==== | ||
+ | * Printed 40 tags |
