location_criteria [2012/04/24 22:10] tim |
location_criteria [2012/10/01 19:15] mflaga |
- | ====== Power ====== | + | ====Requirements==== |
- | 220v service is a minimum for welding and heavy machinery. 440v would be better. | + | * Power: 440v 3-phase ("heavy power") |
+ | * Size: 5,000 sq.ft. - 12,000 sq.ft. | ||
+ | * Office/Finished::Open Area Ratio 50/50, or finishable/divisble by us | ||
+ | * Restrooms: Men's & Women's (at least two restrooms that we can assign) | ||
+ | * Parking: 6-12 paved spaces w/ overflow (on street, adjacent lot after hours, etc) | ||
+ | * Zoning: Light Industrial / Acceptable for Machining | ||
+ | * Internet access available (provider has a presence, or can reasonably establish one) | ||
+ | * Ceiling Height: 12'+ (open areas) | ||
+ | * Access: 1 overhead door | ||
+ | * Other considerations | ||
+ | * Concrete floor in open space | ||
+ | * Acceptable for welding | ||
+ | * Heated | ||
+ | * Location: Close freeway access / within or near Lansing freeway loop (69/96/127) | ||
+ | * Neighborhood: Grandma safe | ||
+ | //note: while the requirements are desired, we respect that there may not be a perfect fit.// | ||
- | ====== Parking ====== | + | [[Principal permitted uses policy]] |
- | i3 has about 8 actual spaces, with additional parking on the street. This works well for daily use (never in my memory using more than their 8 spaces) and parties (overflowing to the street). I suggest that we should look for a location with a similar arrangement. | + | |
- | ====== Area ====== | + | ====Secondary Considerations==== |
- | i3 started out with something like 2k square feet, moved quickly to 5k square feet, and is working hard to double to 10k square feet already. I think we should be looking for 5k+ square feet. | + | * Fire suppression (for insurance / occupancy) |
- | + | * Certificate of occupancy (no major impediments to occupancy) | |
- | ====== Price ====== | + | * Accessibility (or reasonably made accessible) |
- | A few quick google searches, limited mostly to a look through [[http://www.cityfeet.com/cont/mi/lansing-industrial-space]], show space as low as $2.00 / square foot / year. Which works out to $834 / month. 116 Charles is 3,300 square feet, and $810 / month. There seems to be a LOT of attractive space available at these prices. | + | * Non-multistory OR elevator equipped (for accessibility, large equipment movement, etc) |
- | ====== Condition ====== | + | |
- | One thing we're not short on is labor. We've got some of the most skilled volunteers in the Lansing area. If a space is a little rough, I don't think it should scare us off. We fix things. It's what we do. | + | |
====== Locations ====== | ====== Locations ====== | ||
- | ^ Address ^ Area ^ Price ^ | + | [[Individual space data]] (Currently restricted to board members only) |
- | | 116 Charles, Lansing MI | 3,300 sqft | $810 / mo | | + | |
