infrastructure_working_group [2015/08/05 20:16] zimmer62 |
infrastructure_working_group [2017/04/05 00:38] (current) |
Line 27: | Line 27: | ||
Line 65: | Line 75: | ||
* Cons: | * Cons: | ||
* only supports 2.4ghz | * only supports 2.4ghz | ||
- | * NOT 802.1af (48v) compatible | ||
* Info: | * Info: | ||
* [[https://www.ubnt.com/unifi/unifi-ap/|Manufacturer Link]] | * [[https://www.ubnt.com/unifi/unifi-ap/|Manufacturer Link]] | ||
- | * [[http://www.amazon.com/Ubiquiti-Networks-UniFi-Enterprise-System/dp/B005EORRBW/ref=sr_1_1?ie=UTF8&qid=1438804839&sr=8-1&keywords=UAP-3|Amazon]] | + | * [[http://www.amazon.com/Ubiquiti-Networks-UniFi-Enterprise-System/dp/B005EORRBW/ref=sr_1_1?ie=UTF8&qid=1438804839&sr=8-1&keywords=UAP-3|Amazon $192.76]] |
* Additional Equipment needed: | * Additional Equipment needed: | ||
* We will need a cheap switch, or switch with POE injeciton | * We will need a cheap switch, or switch with POE injeciton | ||
* Cat6 wire to install | * Cat6 wire to install | ||
Line 114: | Line 125: | ||
- | TODO: add links and research | + | * Shielded vs Unshielded Cat6 |
* POE switch for access points | * POE switch for access points | ||
