infrastructure_working_group [2015/06/21 16:29] zimmer62 |
infrastructure_working_group [2017/04/05 00:38] (current) |
Line 16: | Line 16: | ||
* Help answer some of the questions below. | * Help answer some of the questions below. | ||
* Tell us your needs or concerns. | * Tell us your needs or concerns. | ||
- | * Join the working group: | + | * Join this working group! |
* To do that, edit this wiki page add your name, and send a message to members@lansingmakersnetwork.org. | * To do that, edit this wiki page add your name, and send a message to members@lansingmakersnetwork.org. | ||
Line 31: | Line 27: | ||
Line 56: | Line 62: | ||
Line 78: | Line 125: | ||
