infrastructure_working_group [2015/06/21 01:32] zimmer62 |
infrastructure_working_group [2017/04/05 00:38] (current) |
Line 10: | Line 10: | ||
Line 19: | Line 27: | ||
Line 44: | Line 62: | ||
Line 60: | Line 119: | ||
* Tim Schmidt has stated he has set it up at home before | * Tim Schmidt has stated he has set it up at home before | ||
* A friend of Joe Zimmerman's uses this at a small community college (he says "It's Awesome") | * A friend of Joe Zimmerman's uses this at a small community college (he says "It's Awesome") | ||
Line 66: | Line 125: | ||
