infrastructure_working_group [2015/06/21 16:39] tim |
infrastructure_working_group [2017/04/05 00:38] (current) |
Line 20: | Line 20: | ||
Line 31: | Line 27: | ||
Line 58: | Line 64: | ||
- How will we allow for VPN connections from outside the building into the member only network? | - How will we allow for VPN connections from outside the building into the member only network? | ||
- How will we allow for members to run servers using static or dynamic IPs? | - How will we allow for members to run servers using static or dynamic IPs? | ||
Line 79: | Line 125: | ||
