infrastructure_working_group [2015/06/19 14:53] zimmer62 created |
infrastructure_working_group [2016/02/25 17:52] zimmer62 |
+ | ======= Infrastructure Working Group ======= | ||
==== Mission: ==== | ==== Mission: ==== | ||
To create a robust, reliable, wireless and wired network at LMN for members, guests and space owned equipment. | To create a robust, reliable, wireless and wired network at LMN for members, guests and space owned equipment. | ||
+ | === Working Group Members: === | ||
+ | * [[user:zimmer62:start|Joe Zimmerman]] | ||
+ | * [[user:tim:start|Tim Schmidt]] | ||
Line 10: | Line 27: | ||
Line 35: | Line 62: | ||
Line 49: | Line 117: | ||
* Simplify network management | * Simplify network management | ||
+ | * Tim Schmidt has stated he has set it up at home before | ||
+ | * A friend of Joe Zimmerman's uses this at a small community college (he says "It's Awesome") | ||
Line 54: | Line 125: | ||
