infrastructure_working_group [2015/08/05 19:42] zimmer62 |
infrastructure_working_group [2015/09/15 03:18] zimmer62 |
Line 27: | Line 27: | ||
+ | * The old SSID of LansingMakers2 still works, however it's using new hardware, this will be deprecated eventually. | ||
+ | There is also a LansingMakersGuest (currently this SSIS is not configured properly, so don't try and use it yet) | ||
+ | You'll notice there are three access points now, 1 on each floor. | ||
+ | 1. The one in the shop is located in the middle of the room. | ||
+ | 2. The on the main floor is located to the right of the stage area | ||
+ | 3. The one on the 3rd floor is located on the back wall near the electronic storage. | ||
+ | If you see any of these access points with the light showing anything other than a solid Green, it would be helpful if you can report that here as well. | ||
+ | Please do not plug in the old Linksys/Cisco access point, it is using the same SSID and will cause problems. | ||
Line 54: | Line 71: | ||
- How will we allow for VPN connections from outside the building into the member only network? | - How will we allow for VPN connections from outside the building into the member only network? | ||
- How will we allow for members to run servers using static or dynamic IPs? | - How will we allow for members to run servers using static or dynamic IPs? | ||
Line 74: | Line 131: | ||
* Suggested by a network admin of a small community college | * Suggested by a network admin of a small community college | ||
TODO: add links and research | TODO: add links and research | ||
- | * Ubiquiti Networks UniFi AP Enterprise WiFi System UAP-3 (Pack of 3) | ||
- | * Under $200 for 3 pack, but only supports 2.4ghz | ||
* POE switch for access points | * POE switch for access points | ||
