infrastructure_working_group [2015/06/25 14:45] zimmer62 |
infrastructure_working_group [2016/02/25 17:52] zimmer62 |
Line 20: | Line 20: | ||
- | * We will be looking at the PacketFence LiveCD and discussing the questions. | ||
Line 32: | Line 27: | ||
Line 59: | Line 64: | ||
- How will we allow for VPN connections from outside the building into the member only network? | - How will we allow for VPN connections from outside the building into the member only network? | ||
- How will we allow for members to run servers using static or dynamic IPs? | - How will we allow for members to run servers using static or dynamic IPs? | ||
Line 79: | Line 124: | ||
* Suggested by a network admin of a small community college | * Suggested by a network admin of a small community college | ||
TODO: add links and research | TODO: add links and research | ||
- | * Ubiquiti Networks UniFi AP Enterprise WiFi System UAP-3 (Pack of 3) | ||
- | * Under $200 for 3 pack, but only supports 2.4ghz | ||
* POE switch for access points | * POE switch for access points | ||
