infrastructure_working_group [2015/06/21 16:29] zimmer62 |
infrastructure_working_group [2015/09/15 03:18] zimmer62 |
Line 16: | Line 16: | ||
* Help answer some of the questions below. | * Help answer some of the questions below. | ||
* Tell us your needs or concerns. | * Tell us your needs or concerns. | ||
- | * Join the working group: | + | * Join this working group! |
* To do that, edit this wiki page add your name, and send a message to members@lansingmakersnetwork.org. | * To do that, edit this wiki page add your name, and send a message to members@lansingmakersnetwork.org. | ||
Line 31: | Line 27: | ||
+ | * The old SSID of LansingMakers2 still works, however it's using new hardware, this will be deprecated eventually. | ||
+ | There is also a LansingMakersGuest (currently this SSIS is not configured properly, so don't try and use it yet) | ||
+ | You'll notice there are three access points now, 1 on each floor. | ||
+ | 1. The one in the shop is located in the middle of the room. | ||
+ | 2. The on the main floor is located to the right of the stage area | ||
+ | 3. The one on the 3rd floor is located on the back wall near the electronic storage. | ||
+ | If you see any of these access points with the light showing anything other than a solid Green, it would be helpful if you can report that here as well. | ||
+ | Please do not plug in the old Linksys/Cisco access point, it is using the same SSID and will cause problems. | ||
Line 56: | Line 69: | ||
Line 78: | Line 132: | ||
