infrastructure_working_group [2015/06/20 17:52] zimmer62 |
infrastructure_working_group [2016/02/25 17:58] zimmer62 |
Line 10: | Line 10: | ||
Line 19: | Line 27: | ||
Line 44: | Line 62: | ||
Line 59: | Line 118: | ||
* Tim Schmidt has stated he has set it up at home before | * Tim Schmidt has stated he has set it up at home before | ||
- | * A friend of Joe Zimmerman's uses this at a small community college (he says "It's Awesome" | + | * A friend of Joe Zimmerman's uses this at a small community college (he says "It's Awesome") |
Line 66: | Line 125: | ||
