infrastructure_working_group [2015/06/19 15:01] zimmer62 |
infrastructure_working_group [2015/09/14 14:13] zimmer62 |
Line 10: | Line 10: | ||
Line 19: | Line 27: | ||
+ | * The old SSID of LansingMakers2 still works, however it's using new hardware, this will be deprecated eventually. | ||
+ | There is also a LansingMakersGuest (currently this SSIS is not configured properly, so don't try and use it yet) | ||
+ | You'll notice there are three access points now, 1 on each floor. | ||
+ | 1. The one in the shop is located in the middle of the room. | ||
+ | 2. The on the main floor is located to the right of the stage area | ||
+ | 3. The one on the 3rd floor is located on the back wall near the electronic storage. | ||
+ | If you see any of these access points with the light showing anything other than a solid Green, it would be helpful if you can report that here as well. | ||
+ | Please do not plug in the old Linksys/Cisco access point, it is using the same SSID and will cause problems. | ||
Line 44: | Line 67: | ||
Line 58: | Line 122: | ||
* Simplify network management | * Simplify network management | ||
+ | * Tim Schmidt has stated he has set it up at home before | ||
+ | * A friend of Joe Zimmerman's uses this at a small community college (he says "It's Awesome") | ||
Line 63: | Line 130: | ||
