infrastructure_working_group [2015/06/19 15:01] zimmer62 |
infrastructure_working_group [2015/08/05 19:42] zimmer62 |
Line 10: | Line 10: | ||
Line 44: | Line 52: | ||
Line 58: | Line 67: | ||
* Simplify network management | * Simplify network management | ||
+ | * Tim Schmidt has stated he has set it up at home before | ||
+ | * A friend of Joe Zimmerman's uses this at a small community college (he says "It's Awesome") | ||
Line 63: | Line 75: | ||
