infrastructure_working_group [2015/06/19 14:59] zimmer62 |
infrastructure_working_group [2015/08/05 20:14] zimmer62 |
+ | ======= Infrastructure Working Group ======= | ||
==== Mission: ==== | ==== Mission: ==== | ||
To create a robust, reliable, wireless and wired network at LMN for members, guests and space owned equipment. | To create a robust, reliable, wireless and wired network at LMN for members, guests and space owned equipment. | ||
Line 8: | Line 10: | ||
Line 42: | Line 52: | ||
+ | * NOT 802.1af (48v) compatible | ||
+ | * [[http://www.amazon.com/Ubiquiti-Networks-UniFi-Enterprise-System/dp/B005EORRBW/ref=sr_1_1?ie=UTF8&qid=1438804839&sr=8-1&keywords=UAP-3|Amazon]] | ||
Line 56: | Line 98: | ||
* Simplify network management | * Simplify network management | ||
+ | * Tim Schmidt has stated he has set it up at home before | ||
+ | * A friend of Joe Zimmerman's uses this at a small community college (he says "It's Awesome") | ||
* Suggested by a network admin of a small community college | * Suggested by a network admin of a small community college | ||
