equipment [2016/01/28 18:26] – Removed some tools no longer at LMN wrealityequipment [2025/07/23 18:37] (current) – lex
-{{page>zones:start&nofooter}}+====== Equipment ======
-===Other Tools=== +The most up-to-date list of equipment can be found on the website. [[https://www.lansingmakersnetwork.org/equipment/|Equipment List]]
-Some tools have yet to be incorporated into the zone pages and are listed below. +
-^ CNC tools ^ Owner ^ Description ^ Current Location ^ +
-^Crafting^ ^ ^ ^ +
-| Sewing Machine | LMN | Brother (non embroidery) - needs repair | [[zones:craft area]]  | +
-| Sewing Machine | ?? | ?? | [[zones:craft area]] | +
-^Metal working ^ ^ ^ ^ +
-| Angle grinder | [[user:tim:start|Timothy Schmidt]] | 4.5 inch angle grinder | [[user:tim:start|Timothy Schmidt]] | +
-| Welder | [[user:zimmer62:start|Joe Zimmerman ]] | flux core wire welder | [[zones:metalshop]]  | +
-| 30" Metal Brake | [[user:zimmer62:start|Joe Zimmerman ]] | [[http://www.harborfreight.com/30-inch-bending-brake-67240.html|30 in. Bending Brake]] | [[zones:metalshop]]  | +
-^ Wood working ^ ^ ^ ^ +
-| Wood Lathe | LMN | 5ft wood lathe | [[zones:woodshop]] | +
-| [[http://www.shopsmith.com/markvsite/|Shopsmith Mark 5]] | [[user:mflaga:start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | [[zones:parts storage]] | +
-| Band Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Band Saw | [[zones:parts storage]] | +
-| Scroll Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Scroll Saw | [[zones:woodshop]]| +
-| Brad Nailer | [[user:zimmer62:start|Joe Zimmerman]] | Pneumatic brad nail gun | [[zones:woodshop]] | +
-| Saw Dust collector/vacuum system | LMN | [[http://www.harborfreight.com/2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] | [[zones:woodshop]]| +
-^ Electronics ^ ^ ^ ^ +
-|Soldering iron|[[user:tim:start|Timothy Schmidt]]|Weller WES51| [[user:tim:start|Timothy Schmidt]] | +
-|Solder sucker|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | +
-|Helping hands|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | +
-^Video^ ^ ^ ^ +
-|Inflatable Movie Screen | [[user:zimmer62:start|Joe Zimmerman]] | Large bouncy-castle style inflatable movie screen w/ projector and speakers - great for movie nights!| [[zones:great room]] | +
-|3M Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | White board w/ built-in 1024x768 video projector, speakers, pen and eraser sensors | [[zones:alcove]] | +
-|Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | Rear-projection 1024x768 interactive projector w/ pen and eraser sensors and Smartboard software | [[zones:great room]] | +
-[[zones:parts storage]] | +
-^Library^ ^ ^ ^ +
-^ Miscellaneous ^ ^ ^ ^ +
-| Sand blaster | LMN | [[http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P| Craftsman Sand Blaster]] | [[zones:parts storage]] | +
-| Air Compressor | [[user:zimmer62:start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | [[zones:woodshop]] | +
-^Hand tools^ ^ ^ ^ +
-| 18 Volt Drill | LMN | Ryobi 18Volt drill | [[zones:woodshop]] | +
-| 18 Volt Impact Driver | LMN | Ryobi 18Volt impact driver | [[zones:woodshop]] | +
-| Screw drivers | LMN | | [[zones:woodshop]] | +
-| Wrenches | LMN | | [[zones:woodshop]] / [[zones:metalshop]] | +
-======Wish List====== +
-^ Item ^ Comment ^ +
-| [[equipment:wishlist:laser_cutter|Additional Laser Cutter]] | [[equipment:wishlist:laser_cutter|60Watt or Greater]] | +
-| Air Compressor | bigger the better | +
-| Vacu-Former | [[user:wreality:start|Brian Adams]] will help/build/lead the project if there's no other takers | +
-| MIG / TIG welding equipment | | +
-| Mitre Saw | | +
-| Planer | [[user:zimmer62:start|Joe Zimmerman]] has one, it's currently on loan to a friend in Grand Rapids |  +
-| Jointer | | +
-| Bridgeport Mill | Manual or CNC | +
-| Drill press | Floor standing | +
-| Arbor press | Hand-operated rack-and-pinion press for installing bearings or broaching | +
-| [[http://www.tools-plus.com/general-woodworking-machinery-50-exbc14.html|General Woodworking Machinery 50-EXBC14 Overarm Blade Guard]] | Besides looking fancy, this thing clears away dust, and is trivial to move out of the way when necessary and back into place afterward - making it a blade guard people might actually use| +
-|screen printer| | +
-| Large cnc embroidery machine| | +
-|car hoist| | +
-|clay body mixer| | +
-|ceramic slab roller| | +
-|pottery wheels| | +
-|electric kilns|hot enough for glass work?| +
-|cnc knitting machine| | +
-|relief printing equipment|carving tools, presses| +
-|loom| | +
-|cnc foam cutter| Hot wire foam cutter http://www.instructables.com/id/Make-a-CNC-Hot-Wire-Foam-Cutter-from-parts-availab/| +
-|cnc fabric cutter|essentially a giant vinyl cutter w/ vacuum table for holding the fabric securely during cutting| +
-|shop press|10 ton or more shop press | +
-|cnc plasma cutter| such as: [[http://torchmate.com/products/]] |+
 +All Areas have an Area Manager, who facilitates and organizes the space and tools. If you have issues with any tools, please let them know by posting on the [[https://talk.lansingmakersnetwork.org/|talksite]].
 +Have an idea for an improvement that you'd like to see? Reach out!
 +The Area Manager list can be found on the website. [[https://www.lansingmakersnetwork.org/leadership/|Area Managers]]
