equipment [2013/12/27 04:45]
tim
equipment [2017/04/05 00:38] (current)
-These are tools available ​to use at the space:+{{page>​zones:​start&​nofooter}}
 +===Other Tools===
 +Some tools have yet to be incorporated into the zone pages and are listed below.
 ^ CNC tools ^ Owner ^ Description ^ Current Location ^ ^ CNC tools ^ Owner ^ Description ^ Current Location ^
-| Vinyl Cutter | Xarrax Lee | USCutters 2ft cutting width | LMN - Craft area|
-| Vinyl Cutter | [[user:​voidptr:​start|Rosangela Canino-Koning]] | 8 1/2" x 11" cutting size | LMN - Craft area|
-| [[:​equipment/​buildlog_laser_cutter|Laser cutter]] | [[user:​tim:​start|Timothy Schmidt]] | 24inch square working area 40watt, [[http://​buildlog.net/​]] laser cutter | LMN - Mezzanine|
-| PCB mill | [[user:​tim:​start|Timothy Schmidt]] | 8 inch x 6 inch x 2 inch CNC dremel mini-mill | LMN - Parts storage|
-| 3D Printers | [[user:​tim:​start|Timothy Schmidt]] | One Rostock and two mendel style [[http://​www.reprap.org/​|repraps]] | LMN - Mezzanine|
-| Shapeoko router | [[user:​zimmer62:​start|Joe Zimmerman]] | http://​www.shapeoko.com/​ | LMN - Basement|
-| CNC Mill | [[user:​carlraymond:​start|Carl Raymond]] | Seig X2 mill converted to CNC with Mach 3 | LMN - Metalshop|
 ^Crafting^ ^ ^ ^ ^Crafting^ ^ ^ ^
-Embroidery ​Machine | [[user:zimmer62:​start|Joe Zimmerman ​]] | Built-in graphics and fonts, as well as custom computer-generated graphics via memory card / reader | LMN +Sewing ​Machine ​| LMN | Brother (non embroidery) - needs repair ​| [[zones:craft area]]
-| Sewing Machine | ?? | ?? | LMN - Craft area | +| Sewing Machine | ?? | ?? | [[zones:craft area]] |
-| Sewing Machine | ?? | ?? | LMN - Craft area| +
-| Spinning Wheel | [[user:tim:​start|Timothy Schmidt]] | ?? | LMN - Craft area +
-| Spinning Wheel | [[user:​tim:​start|Timothy Schmidt]] | ?? | LMN - Craft area|+
 ^Metal working ^ ^ ^ ^ ^Metal working ^ ^ ^ ^
-| Drill Press | [[user:​tim:​start|Timothy Schmidt]] | two 8 inch harbor freight drill presses | LMN/Randy Schott | +| Welder | [[user:​zimmer62:​start|Joe Zimmerman ]] | flux core wire welder | [[zones:metalshop]]
-| Lathe | [[user:​tim:​start|Timothy Schmidt]] | Harbor Freight [[ http://​bedair.org/​9x20camlock/​9x20project.html|9x20]] metalworking lathe | LMN - Metalshop | +| 30" Metal Brake | [[user:​zimmer62:​start|Joe Zimmerman ]] | [[http://​www.harborfreight.com/​30-inch-bending-brake-67240.html|30 in. Bending Brake]] | [[zones:​metalshop]]  ​|
-| Lathe | [[user:​carlraymond:​start|Carl Raymond]] | Micro-Mark 7x14 metalworking lathe | LMN - Metalshop| +
-| Angle grinder | [[user:​tim:​start|Timothy Schmidt]] | 5 inch angle grinder | ? | +
-| Welder | [[user:​tim:​start|Timothy Schmidt]] | 90A 110v flux core wire welder | [[user:​tim:​start|Timothy Schmidt]] | +
-| Welder | [[user:​zimmer62:​start|Joe Zimmerman ]] | flux core wire welder ​| LMN | +
-| Pipe bender ​| [[user:tim:​start|Timothy Schmidt]] | 12 ton harbor freight [[http://​www.harborfreight.com/​12-ton-hydraulic-pipe-bender-32888.html|pipe bender]] | LMN | +
-| Horizontal Cut-Off Band Saw | [[user:​tim:​start|Timothy Schmidt]] | ?? | LMN | +
-| Pipe notcher | [[user:​tim:​start|Timothy Schmidt]] | harbor freight [[http://​www.harborfreight.com/​pipe-tubing-notcher-42324.html|pipe notcher]] | LMN +
-| 30" Metal Brake | [[user:​zimmer62:​start|Joe Zimmerman ]] | [[http://​www.harborfreight.com/​30-inch-bending-brake-67240.html|30 in. Bending Brake]] | LMN |+
 ^ Wood working ^ ^ ^ ^ ^ Wood working ^ ^ ^ ^
-Table saw | [[user:​carlraymond:​start|Carl Raymond]] | Delta table saw | LMN - Woodshop ​| +Wood Lathe | LMN | 5ft wood lathe | [[zones:woodshop]] |
-| Table saw | LMN | Rockwell table saw | LMN - Woodshop | +| [[http://​www.shopsmith.com/​markvsite/​|Shopsmith Mark 5]] | [[user:​mflaga:​start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | [[zones:​parts ​storage]]
-| Router table | [[user:carlraymond:​start|Carl Raymond]] | Homemade table with storage drawers; can make raised panel doors. Needs better fence | LMN - Woodshop | +| Band Saw | [[user:​zimmer62:​start|Joe Zimmerman]] | Small Band Saw | [[zones:​parts ​storage]]
-| Wood Lathe | LMN | 5ft wood lathe | LMN - Woodshop ​+| Scroll Saw | [[user:​zimmer62:​start|Joe Zimmerman]] | Small Scroll Saw | [[zones:​woodshop]]
-| [[http://​www.shopsmith.com/​markvsite/​|Shopsmith Mark 5]] | [[user:​mflaga:​start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | LMN - Basement ​storage+| Brad Nailer | [[user:​zimmer62:​start|Joe Zimmerman]] | Pneumatic brad nail gun | [[zones:​woodshop]] ​
-| Band Saw | LMN | Large free standing band saw | LMN - Woodshop ​+| Saw Dust collector/​vacuum system | LMN | [[http://​www.harborfreight.com/​2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] | [[zones:woodshop]]|
-| Band Saw | [[user:​zimmer62:​start|Joe Zimmerman]] | Small Band Saw | LMN - Parts storage| +
-| Scroll Saw | [[user:​zimmer62:​start|Joe Zimmerman]] | Small Scroll Saw | LMN - Woodshop+
-| Brad Nailer | [[user:​zimmer62:​start|Joe Zimmerman]] | Pneumatic brad nail gun | LMN +
-| Saw Dust collector/​vacuum system | LMN | [[http://​www.harborfreight.com/​2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] ​| LMN - Woodshop| +
-^ Electronics ^ ^ ^ ^ +
-|Soldering iron|[[user:tim:​start|Timothy Schmidt]]|Weller WES51| [[user:​tim:​start|Timothy Schmidt]] | +
-|Solder sucker|[[user:​tim:​start|Timothy Schmidt]]| | [[user:​tim:​start|Timothy Schmidt]] | +
-| Hot-air rework station | [[user:​carlraymond:​start|Carl Raymond]] | SparkFun 303D | LMN | +
-|Helping hands|[[user:​tim:​start|Timothy Schmidt]]| | [[user:​tim:​start|Timothy Schmidt]] |+
 ^Video^ ^ ^ ^ ^Video^ ^ ^ ^
-|Inflatable Movie Screen | [[user:​zimmer62:​start|Joe Zimmerman]] | Large bouncy-castle style inflatable movie screen w/ projector and speakers - great for movie nights!| ​LMN - Great room | +|Inflatable Movie Screen | [[user:​zimmer62:​start|Joe Zimmerman]] | Large bouncy-castle style inflatable movie screen w/ projector and speakers - great for movie nights!| ​[[zones:​great ​room]]
-|3M Smart Board| [[user:​zimmer62:​start|Joe Zimmerman]] | White board w/ built-in 1024x768 video projector, speakers, pen and eraser sensors | LMN - Alcove ​+|3M Smart Board| [[user:​zimmer62:​start|Joe Zimmerman]] | White board w/ built-in 1024x768 video projector, speakers, pen and eraser sensors | [[zones:​alcove]] ​
-|Smart Board| [[user:​zimmer62:​start|Joe Zimmerman]] | Rear-projection 1024x768 interactive projector w/ pen and eraser sensors and Smartboard software ​| LMN - Great room | +|Smart Board| [[user:​zimmer62:​start|Joe Zimmerman]] | Rear-projection 1024x768 interactive projector w/ pen and eraser sensors and Smartboard software | [[zones:great room]] |
-|Plextor PX-TV402U|[[user:tim:​start|Timothy Schmidt]]|USB Hardware MPEG4 A/V input / analog TV tuner. ​ Coaxial, RCA, and S-Video inputs| LMN - Parts storage+[[zones:parts storage]] |
-^Communications^ ^ ^ ^ +
-|Sipura SPA 2002|[[user:tim:​start|Timothy Schmidt]]|10/100 ethernet SIP Analog telephone adapter w/ two independent phone ports| LMN - Parts storage|+
 ^Library^ ^ ^ ^ ^Library^ ^ ^ ^
 ^ Miscellaneous ^ ^ ^ ^ ^ Miscellaneous ^ ^ ^ ^
-| Sand blaster | [[user:​tim:​start|Timothy Schmidt]] | [[http://​www.harborfreight.com/​40-lb-pressurized-abrasive-blaster-68992.html|40lb pressurized abrasive blaster]] -- requires very large air compressor | LMN - Parts storage| +| Sand blaster | LMN | [[http://​www.sears.com/​craftsman-50-lb-sandblaster-kit-with-1-4-in/​p-00916706000P| Craftsman Sand Blaster]] | [[zones:​parts storage]] ​
-| Sand blaster | LMN | [[http://​www.sears.com/​craftsman-50-lb-sandblaster-kit-with-1-4-in/​p-00916706000P| Craftsman Sand Blaster]] | LMN +| Air Compressor | [[user:​zimmer62:​start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | [[zones:​woodshop]] ​|
-| Air Compressor | [[user:​zimmer62:​start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | LMN |+
 ^Hand tools^ ^ ^ ^ ^Hand tools^ ^ ^ ^
-Cordless drills / screw drivers ​| | | LMN - Woodshop ​+18 Volt Drill LMN Ryobi 18Volt drill | [[zones:​woodshop]] |
-| Screw drivers | LMN | | LMN - Woodshop ​+| 18 Volt Impact Driver ​| LMN | Ryobi 18Volt impact driver | [[zones:​woodshop]] ​
-| Wrenches | LMN | | LMN - Woodshop ​Metalshop ​|+| Screw drivers | LMN | | [[zones:​woodshop]] ​
 +| Wrenches | LMN | | [[zones:​woodshop]] ​[[zones:​metalshop]] ​|
Line 64: Line 41:
 ======Wish List====== ======Wish List======
 ^ Item ^ Comment ^ ^ Item ^ Comment ^
 +| [[equipment:​wishlist:​laser_cutter|Additional Laser Cutter]] | [[equipment:​wishlist:​laser_cutter|60Watt or Greater]] |
 | Air Compressor | bigger the better | | Air Compressor | bigger the better |
 | Vacu-Former | [[user:​wreality:​start|Brian Adams]] will help/​build/​lead the project if there'​s no other takers | | Vacu-Former | [[user:​wreality:​start|Brian Adams]] will help/​build/​lead the project if there'​s no other takers |
 | MIG / TIG welding equipment | | | MIG / TIG welding equipment | |
 | Mitre Saw | | | Mitre Saw | |
-| Planer | |+| Planer | [[user:​zimmer62:​start|Joe Zimmerman]] has one, it's currently on loan to a friend in Grand Rapids ​
 | Jointer | | | Jointer | |
 | Bridgeport Mill | Manual or CNC | | Bridgeport Mill | Manual or CNC |
