equipment [2014/05/09 22:20] wreality |
equipment [2016/01/28 18:26] wreality Removed some tools no longer at LMN |
- | {{page>zones:start}} | + | {{page>zones:start&nofooter}} |
+ | ===Other Tools=== | ||
Some tools have yet to be incorporated into the zone pages and are listed below. | Some tools have yet to be incorporated into the zone pages and are listed below. | ||
- | | [[equipment:shapeoko|Shapeoko router]] | [[user:zimmer62:start|Joe Zimmerman]] | http://www.shapeoko.com/ | [[zones:woodshop]] | | ||
| Sewing Machine | LMN | Brother (non embroidery) - needs repair | [[zones:craft area]] | | | Sewing Machine | LMN | Brother (non embroidery) - needs repair | [[zones:craft area]] | | ||
| Sewing Machine | ?? | ?? | [[zones:craft area]] | | | Sewing Machine | ?? | ?? | [[zones:craft area]] | | ||
- | | Spinning Wheel | [[user:tim:start|Timothy Schmidt]] | ?? | [[zones:craft area]] | | + | |
- | | Drill Press | [[user:tim:start|Timothy Schmidt]] | two 8 inch harbor freight drill presses | [[user:rschott:start|Randy Schott]] | | ||
- | | Lathe | [[user:tim:start|Timothy Schmidt]] | Harbor Freight [[ http://bedair.org/9x20camlock/9x20project.html|9x20]] metalworking lathe | [[zones:metalshop]] | | ||
| Angle grinder | [[user:tim:start|Timothy Schmidt]] | 4.5 inch angle grinder | [[user:tim:start|Timothy Schmidt]] | | | Angle grinder | [[user:tim:start|Timothy Schmidt]] | 4.5 inch angle grinder | [[user:tim:start|Timothy Schmidt]] | | ||
- | | Welder | [[user:tim:start|Timothy Schmidt]] | 90A 110v flux core wire welder | [[user:tim:start|Timothy Schmidt]] | | ||
| Welder | [[user:zimmer62:start|Joe Zimmerman ]] | flux core wire welder | [[zones:metalshop]] | | | Welder | [[user:zimmer62:start|Joe Zimmerman ]] | flux core wire welder | [[zones:metalshop]] | | ||
- | | Pipe bender | [[user:tim:start|Timothy Schmidt]] | 12 ton harbor freight [[http://www.harborfreight.com/12-ton-hydraulic-pipe-bender-32888.html|pipe bender]] | [[zones:metalshop]] | | ||
- | | Horizontal Cut-Off Band Saw | [[user:tim:start|Timothy Schmidt]] | ?? | [[zones:metalshop]] | | ||
- | | Pipe notcher | [[user:tim:start|Timothy Schmidt]] | harbor freight [[http://www.harborfreight.com/pipe-tubing-notcher-42324.html|pipe notcher]] | [[zones:metalshop]] | | ||
| 30" Metal Brake | [[user:zimmer62:start|Joe Zimmerman ]] | [[http://www.harborfreight.com/30-inch-bending-brake-67240.html|30 in. Bending Brake]] | [[zones:metalshop]] | | | 30" Metal Brake | [[user:zimmer62:start|Joe Zimmerman ]] | [[http://www.harborfreight.com/30-inch-bending-brake-67240.html|30 in. Bending Brake]] | [[zones:metalshop]] | | ||
- | | Table saw | LMN | Rockwell table saw | [[zones:woodshop]] | | ||
| Wood Lathe | LMN | 5ft wood lathe | [[zones:woodshop]] | | | Wood Lathe | LMN | 5ft wood lathe | [[zones:woodshop]] | | ||
| [[http://www.shopsmith.com/markvsite/|Shopsmith Mark 5]] | [[user:mflaga:start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | [[zones:parts storage]] | | | [[http://www.shopsmith.com/markvsite/|Shopsmith Mark 5]] | [[user:mflaga:start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | [[zones:parts storage]] | | ||
Line 40: | Line 23: | ||
|Soldering iron|[[user:tim:start|Timothy Schmidt]]|Weller WES51| [[user:tim:start|Timothy Schmidt]] | | |Soldering iron|[[user:tim:start|Timothy Schmidt]]|Weller WES51| [[user:tim:start|Timothy Schmidt]] | | ||
|Solder sucker|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | |Solder sucker|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | ||
- | | Hot-air rework station | [[user:carlraymond:start|Carl Raymond]] | SparkFun 303D | [[zones:electronics]] | | ||
|Helping hands|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | |Helping hands|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | ||
Line 46: | Line 28: | ||
|3M Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | White board w/ built-in 1024x768 video projector, speakers, pen and eraser sensors | [[zones:alcove]] | | |3M Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | White board w/ built-in 1024x768 video projector, speakers, pen and eraser sensors | [[zones:alcove]] | | ||
|Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | Rear-projection 1024x768 interactive projector w/ pen and eraser sensors and Smartboard software | [[zones:great room]] | | |Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | Rear-projection 1024x768 interactive projector w/ pen and eraser sensors and Smartboard software | [[zones:great room]] | | ||
- | |Plextor PX-TV402U|[[user:tim:start|Timothy Schmidt]]|USB Hardware MPEG4 A/V input / analog TV tuner. Coaxial, RCA, and S-Video inputs| [[zones:parts storage]] | | + | [[zones:parts storage]] | |
- | |Sipura SPA 2002|[[user:tim:start|Timothy Schmidt]]|10/100 ethernet SIP Analog telephone adapter w/ two independent phone ports| [[zones:parts storage]] | | + | |
- | | Sand blaster | [[user:tim:start|Timothy Schmidt]] | [[http://www.harborfreight.com/40-lb-pressurized-abrasive-blaster-68992.html|40lb pressurized abrasive blaster]] -- requires very large air compressor | [[zones:parts storage]] | | ||
| Sand blaster | LMN | [[http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P| Craftsman Sand Blaster]] | [[zones:parts storage]] | | | Sand blaster | LMN | [[http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P| Craftsman Sand Blaster]] | [[zones:parts storage]] | | ||
| Air Compressor | [[user:zimmer62:start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | [[zones:woodshop]] | | | Air Compressor | [[user:zimmer62:start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | [[zones:woodshop]] | | ||
Line 65: | Line 45: | ||
