equipment [2014/01/02 20:21] zimmer62 |
equipment [2017/04/05 00:38] |
- | These are tools available to use at the space: | ||
- | ^ CNC tools ^ Owner ^ Description ^ Current Location ^ | ||
- | | Vinyl Cutter | Xarrax Lee | USCutters 2ft cutting width | LMN - Craft area| | ||
- | | Vinyl Cutter | [[user:voidptr:start|Rosangela Canino-Koning]] | 8 1/2" x 11" cutting size | LMN - Craft area| | ||
- | | 3D Printers | [[user:tim:start|Timothy Schmidt]] | Two mendel style [[http://www.reprap.org/|repraps]] | LMN - Mezzanine| | ||
- | | Rostock 3D Printer | LMN | Rostock 3d printer | LMN - Mezzanine | | ||
- | | Solidoodle2 | [[user:zimmer62:start|Joe Zimmerman]] | Solidoode2 3d Printer | LMN - Mezzanine| | ||
- | ^Crafting^ ^ ^ ^ | ||
- | | Embroidery Machine | [[user:zimmer62:start|Joe Zimmerman ]] | Built-in graphics and fonts, as well as custom computer-generated graphics via memory card / reader | LMN | | ||
- | | Sewing Machine | LMN | Brother (non embroidery) - needs repair | LMN - Craft area | | ||
- | | Sewing Machine | ?? | ?? | LMN - Craft area| | ||
- | | Spinning Wheel | [[user:tim:start|Timothy Schmidt]] | ?? | LMN - Craft area | | ||
- | | Spinning Wheel | [[user:tim:start|Timothy Schmidt]] | ?? | LMN - Craft area| | ||
- | ^Metal working ^ ^ ^ ^ | ||
- | | Drill Press | [[user:tim:start|Timothy Schmidt]] | two 8 inch harbor freight drill presses | LMN/Randy Schott | | ||
- | | Lathe | [[user:tim:start|Timothy Schmidt]] | Harbor Freight [[ http://bedair.org/9x20camlock/9x20project.html|9x20]] metalworking lathe | LMN - Metalshop | | ||
- | | Lathe | [[user:carlraymond:start|Carl Raymond]] | Micro-Mark 7x14 metalworking lathe | LMN - Metalshop| | ||
- | | Angle grinder | [[user:tim:start|Timothy Schmidt]] | 5 inch angle grinder | ? | | ||
- | | Welder | [[user:tim:start|Timothy Schmidt]] | 90A 110v flux core wire welder | [[user:tim:start|Timothy Schmidt]] | | ||
- | | Welder | [[user:zimmer62:start|Joe Zimmerman ]] | flux core wire welder | LMN | | ||
- | | Pipe bender | [[user:tim:start|Timothy Schmidt]] | 12 ton harbor freight [[http://www.harborfreight.com/12-ton-hydraulic-pipe-bender-32888.html|pipe bender]] | LMN | | ||
- | | Horizontal Cut-Off Band Saw | [[user:tim:start|Timothy Schmidt]] | ?? | LMN | | ||
- | | Pipe notcher | [[user:tim:start|Timothy Schmidt]] | harbor freight [[http://www.harborfreight.com/pipe-tubing-notcher-42324.html|pipe notcher]] | LMN | | ||
- | | 30" Metal Brake | [[user:zimmer62:start|Joe Zimmerman ]] | [[http://www.harborfreight.com/30-inch-bending-brake-67240.html|30 in. Bending Brake]] | LMN | | ||
- | ^ Wood working ^ ^ ^ ^ | ||
- | | Table saw | [[user:carlraymond:start|Carl Raymond]] | Delta table saw | LMN - Woodshop | | ||
- | | Table saw | LMN | Rockwell table saw | LMN - Woodshop | | ||
- | | Router table | [[user:carlraymond:start|Carl Raymond]] | Homemade table with storage drawers; can make raised panel doors. Needs better fence | LMN - Woodshop | | ||
- | | Wood Lathe | LMN | 5ft wood lathe | LMN - Woodshop | | ||
- | | [[http://www.shopsmith.com/markvsite/|Shopsmith Mark 5]] | [[user:mflaga:start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | LMN - Basement storage| | ||
- | | Band Saw | LMN | Large free standing band saw | LMN - Woodshop | | ||
- | | Band Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Band Saw | LMN - Parts storage| | ||
- | | Scroll Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Scroll Saw | LMN - Woodshop| | ||
- | | Brad Nailer | [[user:zimmer62:start|Joe Zimmerman]] | Pneumatic brad nail gun | LMN | | ||
- | | Saw Dust collector/vacuum system | LMN | [[http://www.harborfreight.com/2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] | LMN - Woodshop| | ||
- | ^ Electronics ^ ^ ^ ^ | ||
- | |Soldering iron|[[user:tim:start|Timothy Schmidt]]|Weller WES51| [[user:tim:start|Timothy Schmidt]] | | ||
- | |Solder sucker|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | ||
- | | Hot-air rework station | [[user:carlraymond:start|Carl Raymond]] | SparkFun 303D | LMN | | ||
- | |Helping hands|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | ||
- | ^Video^ ^ ^ ^ | ||
- | |Inflatable Movie Screen | [[user:zimmer62:start|Joe Zimmerman]] | Large bouncy-castle style inflatable movie screen w/ projector and speakers - great for movie nights!| LMN - Great room | | ||
- | |3M Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | White board w/ built-in 1024x768 video projector, speakers, pen and eraser sensors | LMN - Alcove | | ||
- | |Smart Board| [[user:zimmer62:start|Joe Zimmerman]] | Rear-projection 1024x768 interactive projector w/ pen and eraser sensors and Smartboard software | LMN - Great room | | ||
- | |Plextor PX-TV402U|[[user:tim:start|Timothy Schmidt]]|USB Hardware MPEG4 A/V input / analog TV tuner. Coaxial, RCA, and S-Video inputs| LMN - Parts storage| | ||
- | ^Communications^ ^ ^ ^ | ||
- | |Sipura SPA 2002|[[user:tim:start|Timothy Schmidt]]|10/100 ethernet SIP Analog telephone adapter w/ two independent phone ports| LMN - Parts storage| | ||
- | ^Library^ ^ ^ ^ | ||
- | ^ Miscellaneous ^ ^ ^ ^ | ||
- | | Sand blaster | [[user:tim:start|Timothy Schmidt]] | [[http://www.harborfreight.com/40-lb-pressurized-abrasive-blaster-68992.html|40lb pressurized abrasive blaster]] -- requires very large air compressor | LMN - Parts storage| | ||
- | | Sand blaster | LMN | [[http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P| Craftsman Sand Blaster]] | LMN | | ||
- | | Air Compressor | [[user:zimmer62:start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | LMN | | ||
- | ^Hand tools^ ^ ^ ^ | ||
- | | 18 Volt Drill | LMN | Ryobi 18Volt drill | LMN - Woodshop | | ||
- | | 18 Volt Impact Driver | LMN | Ryobi 18Volt impact driver | LMN - Woodshop | | ||
- | | Screw drivers | LMN | | LMN - Woodshop | | ||
- | | Wrenches | LMN | | LMN - Woodshop / Metalshop | | ||
- | ======Wish List====== | ||
- | ^ Item ^ Comment ^ | ||
- | | Air Compressor | bigger the better | | ||
- | | Vacu-Former | [[user:wreality:start|Brian Adams]] will help/build/lead the project if there's no other takers | | ||
- | | MIG / TIG welding equipment | | | ||
- | | Mitre Saw | | | ||
- | | Planer | [[user:zimmer62:start|Joe Zimmerman]] has one, it's currently on loan to a friend in Grand Rapids | | ||
- | | Jointer | | | ||
- | | Bridgeport Mill | Manual or CNC | | ||
- | | Drill press | Floor standing | | ||
- | | Arbor press | Hand-operated rack-and-pinion press for installing bearings or broaching | | ||
- | | [[http://www.tools-plus.com/general-woodworking-machinery-50-exbc14.html|General Woodworking Machinery 50-EXBC14 Overarm Blade Guard]] | Besides looking fancy, this thing clears away dust, and is trivial to move out of the way when necessary and back into place afterward - making it a blade guard people might actually use| | ||
- | |screen printer| | | ||
- | | Large cnc embroidery machine| | | ||
- | |car hoist| | | ||
- | |clay body mixer| | | ||
- | |ceramic slab roller| | | ||
- | |pottery wheels| | | ||
- | |electric kilns|hot enough for glass work?| | ||
- | |cnc knitting machine| | | ||
- | |relief printing equipment|carving tools, presses| | ||
- | |loom| | | ||
- | |cnc foam cutter| Hot wire foam cutter http://www.instructables.com/id/Make-a-CNC-Hot-Wire-Foam-Cutter-from-parts-availab/| | ||
- | |cnc fabric cutter|essentially a giant vinyl cutter w/ vacuum table for holding the fabric securely during cutting| | ||
- | |shop press|10 ton or more shop press | | ||
- | |cnc plasma cutter| such as: [[http://torchmate.com/products/]] | | ||
