equipment [2014/01/02 19:29]
zimmer62
equipment [2017/04/05 00:38]
-These are tools available to use at the space:
-^ CNC tools ^ Owner ^ Description ^ Current Location ^
-| Vinyl Cutter | Xarrax Lee | USCutters 2ft cutting width | LMN - Craft area|
-| Vinyl Cutter | [[user:​voidptr:​start|Rosangela Canino-Koning]] | 8 1/2" x 11" cutting size | LMN - Craft area|
-| [[:​equipment/​buildlog_laser_cutter|Laser cutter]] | [[user:​tim:​start|Timothy Schmidt]] | 24inch square working area 40watt, [[http://​buildlog.net/​]] laser cutter | LMN - Mezzanine|
-| PCB mill | [[user:​tim:​start|Timothy Schmidt]] | 8 inch x 6 inch x 2 inch CNC dremel mini-mill | LMN - Parts storage|
-| 3D Printers | [[user:​tim:​start|Timothy Schmidt]] | One Rostock and two mendel style [[http://​www.reprap.org/​|repraps]] | LMN - Mezzanine|
-| [[equipment:​shapeoko|Shapeoko router]] | [[user:​zimmer62:​start|Joe Zimmerman]] | http://​www.shapeoko.com/​ | LMN - Basement|
-| CNC Mill | [[user:​carlraymond:​start|Carl Raymond]] | Seig X2 mill converted to CNC with Mach 3 | LMN - Metalshop|
-^Crafting^ ^ ^ ^
-| Embroidery Machine | [[user:​zimmer62:​start|Joe Zimmerman ]] | Built-in graphics and fonts, as well as custom computer-generated graphics via memory card / reader | LMN |
-| Sewing Machine | ?? | ?? | LMN - Craft area |
-| Sewing Machine | ?? | ?? | LMN - Craft area|
-| Spinning Wheel | [[user:​tim:​start|Timothy Schmidt]] | ?? | LMN - Craft area |
-| Spinning Wheel | [[user:​tim:​start|Timothy Schmidt]] | ?? | LMN - Craft area|
-^Metal working ^ ^ ^ ^
-| Drill Press | [[user:​tim:​start|Timothy Schmidt]] | two 8 inch harbor freight drill presses | LMN/Randy Schott |
-| Lathe | [[user:​tim:​start|Timothy Schmidt]] | Harbor Freight [[ http://​bedair.org/​9x20camlock/​9x20project.html|9x20]] metalworking lathe | LMN - Metalshop |
-| Lathe | [[user:​carlraymond:​start|Carl Raymond]] | Micro-Mark 7x14 metalworking lathe | LMN - Metalshop|
-| Angle grinder | [[user:​tim:​start|Timothy Schmidt]] | 5 inch angle grinder | ? |
-| Welder | [[user:​tim:​start|Timothy Schmidt]] | 90A 110v flux core wire welder | [[user:​tim:​start|Timothy Schmidt]] |
-| Welder | [[user:​zimmer62:​start|Joe Zimmerman ]] | flux core wire welder | LMN |
-| Pipe bender | [[user:​tim:​start|Timothy Schmidt]] | 12 ton harbor freight [[http://​www.harborfreight.com/​12-ton-hydraulic-pipe-bender-32888.html|pipe bender]] | LMN |
-| Horizontal Cut-Off Band Saw | [[user:​tim:​start|Timothy Schmidt]] | ?? | LMN |
-| Pipe notcher | [[user:​tim:​start|Timothy Schmidt]] | harbor freight [[http://​www.harborfreight.com/​pipe-tubing-notcher-42324.html|pipe notcher]] | LMN |
-| 30" Metal Brake | [[user:​zimmer62:​start|Joe Zimmerman ]] | [[http://​www.harborfreight.com/​30-inch-bending-brake-67240.html|30 in. Bending Brake]] | LMN |
-^ Wood working ^ ^ ^ ^
-| Table saw | [[user:​carlraymond:​start|Carl Raymond]] | Delta table saw | LMN - Woodshop |
-| Table saw | LMN | Rockwell table saw | LMN - Woodshop |
-| Router table | [[user:​carlraymond:​start|Carl Raymond]] | Homemade table with storage drawers; can make raised panel doors. Needs better fence | LMN - Woodshop |
-| Wood Lathe | LMN | 5ft wood lathe | LMN - Woodshop |
-| [[http://​www.shopsmith.com/​markvsite/​|Shopsmith Mark 5]] | [[user:​mflaga:​start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | LMN - Basement storage|
-| Band Saw | LMN | Large free standing band saw | LMN - Woodshop |
-| Band Saw | [[user:​zimmer62:​start|Joe Zimmerman]] | Small Band Saw | LMN - Parts storage|
-| Scroll Saw | [[user:​zimmer62:​start|Joe Zimmerman]] | Small Scroll Saw | LMN - Woodshop|
-| Brad Nailer | [[user:​zimmer62:​start|Joe Zimmerman]] | Pneumatic brad nail gun | LMN |
-| Saw Dust collector/​vacuum system | LMN | [[http://​www.harborfreight.com/​2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] | LMN - Woodshop|
-^ Electronics ^ ^ ^ ^
-|Soldering iron|[[user:​tim:​start|Timothy Schmidt]]|Weller WES51| [[user:​tim:​start|Timothy Schmidt]] |
-|Solder sucker|[[user:​tim:​start|Timothy Schmidt]]| | [[user:​tim:​start|Timothy Schmidt]] |
-| Hot-air rework station | [[user:​carlraymond:​start|Carl Raymond]] | SparkFun 303D | LMN |
-|Helping hands|[[user:​tim:​start|Timothy Schmidt]]| | [[user:​tim:​start|Timothy Schmidt]] |
-^Video^ ^ ^ ^
-|Inflatable Movie Screen | [[user:​zimmer62:​start|Joe Zimmerman]] | Large bouncy-castle style inflatable movie screen w/ projector and speakers - great for movie nights!| LMN - Great room |
-|3M Smart Board| [[user:​zimmer62:​start|Joe Zimmerman]] | White board w/ built-in 1024x768 video projector, speakers, pen and eraser sensors | LMN - Alcove |
-|Smart Board| [[user:​zimmer62:​start|Joe Zimmerman]] | Rear-projection 1024x768 interactive projector w/ pen and eraser sensors and Smartboard software | LMN - Great room |
-|Plextor PX-TV402U|[[user:​tim:​start|Timothy Schmidt]]|USB Hardware MPEG4 A/V input / analog TV tuner. ​ Coaxial, RCA, and S-Video inputs| LMN - Parts storage|
-^Communications^ ^ ^ ^
-|Sipura SPA 2002|[[user:​tim:​start|Timothy Schmidt]]|10/​100 ethernet SIP Analog telephone adapter w/ two independent phone ports| LMN - Parts storage|
-^Library^ ^ ^ ^
-^ Miscellaneous ^ ^ ^ ^
-| Sand blaster | [[user:​tim:​start|Timothy Schmidt]] | [[http://​www.harborfreight.com/​40-lb-pressurized-abrasive-blaster-68992.html|40lb pressurized abrasive blaster]] -- requires very large air compressor | LMN - Parts storage|
-| Sand blaster | LMN | [[http://​www.sears.com/​craftsman-50-lb-sandblaster-kit-with-1-4-in/​p-00916706000P| Craftsman Sand Blaster]] | LMN |
-| Air Compressor | [[user:​zimmer62:​start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | LMN |
-^Hand tools^ ^ ^ ^
-| Cordless drills / screw drivers | | | LMN - Woodshop |
-| Screw drivers | LMN | | LMN - Woodshop |
-| Wrenches | LMN | | LMN - Woodshop / Metalshop |
-======Wish List======
-^ Item ^ Comment ^
-| Air Compressor | bigger the better |
-| Vacu-Former | [[user:​wreality:​start|Brian Adams]] will help/​build/​lead the project if there'​s no other takers |
-| MIG / TIG welding equipment | |
-| Mitre Saw | |
-| Planer | |
-| Jointer | |
-| Bridgeport Mill | Manual or CNC |
-| Drill press | Floor standing |
-| Arbor press | Hand-operated rack-and-pinion press for installing bearings or broaching |
-| [[http://​www.tools-plus.com/​general-woodworking-machinery-50-exbc14.html|General Woodworking Machinery 50-EXBC14 Overarm Blade Guard]] | Besides looking fancy, this thing clears away dust, and is trivial to move out of the way when necessary and back into place afterward - making it a blade guard people might actually use|
-|screen printer| |
-| Large cnc embroidery machine| |
-|car hoist| |
-|clay body mixer| |
-|ceramic slab roller| |
-|pottery wheels| |
-|electric kilns|hot enough for glass work?|
-|cnc knitting machine| |
-|relief printing equipment|carving tools, presses|
-|loom| |
-|cnc foam cutter| Hot wire foam cutter http://​www.instructables.com/​id/​Make-a-CNC-Hot-Wire-Foam-Cutter-from-parts-availab/​|
-|cnc fabric cutter|essentially a giant vinyl cutter w/ vacuum table for holding the fabric securely during cutting|
-|shop press|10 ton or more shop press |
-|cnc plasma cutter| such as: [[http://​torchmate.com/​products/​]] |
