equipment [2013/12/27 04:45] tim |
equipment [2016/01/28 18:35] wreality Removed some tools no longer at LMN |
+ | ===Other Tools=== | ||
- | | Vinyl Cutter | Xarrax Lee | USCutters 2ft cutting width | LMN - Craft area| | ||
- | | Vinyl Cutter | [[user:voidptr:start|Rose Canino-Koning]] | 8 1/2" x 11" cutting size | LMN - Craft area| | ||
- | | 3D Printers | [[user:tim:start|Timothy Schmidt]] | One Rostock and two mendel style [[http://www.reprap.org/|repraps]] | LMN - Mezzanine| | ||
- | | Shapeoko router | [[user:zimmer62:start|Joe Zimmerman]] | http://www.shapeoko.com/ | LMN - Basement| | ||
- | | Embroidery Machine | [[user:zimmer62:start|Joe Zimmerman ]] | Built-in graphics and fonts, as well as custom computer-generated graphics via memory card / reader | LMN | | + | | Sewing Machine | LMN | Brother (non embroidery) - needs repair | [[zones:craft area]] | |
- | | Sewing Machine | ?? | ?? | LMN - Craft area | | + | | Sewing Machine | ?? | ?? | [[zones:craft area]] | |
- | | Drill Press | [[user:tim:start|Timothy Schmidt]] | two 8 inch harbor freight drill presses | LMN/Randy Schott | | + | | Angle grinder | [[user:tim:start|Timothy Schmidt]] | 4.5 inch angle grinder | [[user:tim:start|Timothy Schmidt]] | |
- | | Lathe | [[user:tim:start|Timothy Schmidt]] | Harbor Freight [[ http://bedair.org/9x20camlock/9x20project.html|9x20]] metalworking lathe | LMN - Metalshop | | + | | Welder | [[user:zimmer62:start|Joe Zimmerman ]] | flux core wire welder | [[zones:metalshop]] | |
- | | Lathe | [[user:carlraymond:start|Carl Raymond]] | Micro-Mark 7x14 metalworking lathe | LMN - Metalshop| | + | | 30" Metal Brake | [[user:zimmer62:start|Joe Zimmerman ]] | [[http://www.harborfreight.com/30-inch-bending-brake-67240.html|30 in. Bending Brake]] | [[zones:metalshop]] | |
- | | Router table | [[user:carlraymond:start|Carl Raymond]] | Homemade table with storage drawers; can make raised panel doors. Needs better fence | LMN - Woodshop | | + | | Band Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Band Saw | [[zones:parts storage]] | |
- | | Wood Lathe | LMN | 5ft wood lathe | LMN - Woodshop | | + | | Scroll Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Scroll Saw | [[zones:woodshop]]| |
- | | [[http://www.shopsmith.com/markvsite/|Shopsmith Mark 5]] | [[user:mflaga:start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | LMN - Basement storage| | + | | Brad Nailer | [[user:zimmer62:start|Joe Zimmerman]] | Pneumatic brad nail gun | [[zones:woodshop]] | |
- | | Band Saw | LMN | Large free standing band saw | LMN - Woodshop | | + | | Saw Dust collector/vacuum system | LMN | [[http://www.harborfreight.com/2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] | [[zones:woodshop]]| |
- | |Plextor PX-TV402U|[[user:tim:start|Timothy Schmidt]]|USB Hardware MPEG4 A/V input / analog TV tuner. Coaxial, RCA, and S-Video inputs| LMN - Parts storage| | + | [[zones:parts storage]] | |
- | | Sand blaster | [[user:tim:start|Timothy Schmidt]] | [[http://www.harborfreight.com/40-lb-pressurized-abrasive-blaster-68992.html|40lb pressurized abrasive blaster]] -- requires very large air compressor | LMN - Parts storage| | + | | Sand blaster | LMN | [[http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P| Craftsman Sand Blaster]] | [[zones:parts storage]] | |
- | | Cordless drills / screw drivers | | | LMN - Woodshop | | + | | 18 Volt Drill | LMN | Ryobi 18Volt drill | [[zones:woodshop]] | |
- | | Screw drivers | LMN | | LMN - Woodshop | | + | | 18 Volt Impact Driver | LMN | Ryobi 18Volt impact driver | [[zones:woodshop]] | |
- | | Wrenches | LMN | | LMN - Woodshop / Metalshop | | + | | Screw drivers | LMN | | [[zones:woodshop]] | |
+ | | Wrenches | LMN | | [[zones:woodshop]] / [[zones:metalshop]] | | ||
Line 64: | Line 42: | ||
| Vacu-Former | [[user:wreality:start|Brian Adams]] will help/build/lead the project if there's no other takers | | | Vacu-Former | [[user:wreality:start|Brian Adams]] will help/build/lead the project if there's no other takers | | ||
| MIG / TIG welding equipment | | | | MIG / TIG welding equipment | | | ||
| Mitre Saw | | | | Mitre Saw | | | ||
- | | Planer | | | + | | Planer | [[user:zimmer62:start|Joe Zimmerman]] has one, it's currently on loan to a friend in Grand Rapids | |
| Jointer | | | | Jointer | | | ||
| Bridgeport Mill | Manual or CNC | | | Bridgeport Mill | Manual or CNC | |
