equipment [2014/01/10 03:02] tim |
equipment [2015/08/05 19:26] zimmer62 |
+ | ===Other Tools=== | ||
| Sewing Machine | LMN | Brother (non embroidery) - needs repair | [[zones:craft area]] | | | Sewing Machine | LMN | Brother (non embroidery) - needs repair | [[zones:craft area]] | | ||
| Sewing Machine | ?? | ?? | [[zones:craft area]] | | | Sewing Machine | ?? | ?? | [[zones:craft area]] | | ||
Line 19: | Line 11: | ||
| Spinning Wheel | [[user:tim:start|Timothy Schmidt]] | ?? | [[zones:craft area]] | | | Spinning Wheel | [[user:tim:start|Timothy Schmidt]] | ?? | [[zones:craft area]] | | ||
- | | Drill Press | [[user:tim:start|Timothy Schmidt]] | two 8 inch harbor freight drill presses | LMN/Randy Schott | | + | | Angle grinder | [[user:tim:start|Timothy Schmidt]] | 4.5 inch angle grinder | [[user:tim:start|Timothy Schmidt]] | |
- | | Lathe | [[user:tim:start|Timothy Schmidt]] | Harbor Freight [[ http://bedair.org/9x20camlock/9x20project.html|9x20]] metalworking lathe | LMN - Metalshop | | + | | Welder | [[user:zimmer62:start|Joe Zimmerman ]] | flux core wire welder | [[zones:metalshop]] | |
- | | Lathe | [[user:carlraymond:start|Carl Raymond]] | Micro-Mark 7x14 metalworking lathe | LMN - Metalshop| | + | | Horizontal Cut-Off Band Saw | [[user:tim:start|Timothy Schmidt]] | ?? | [[zones:metalshop]] | |
- | | Angle grinder | [[user:tim:start|Timothy Schmidt]] | 5 inch angle grinder | ? | | + | | 30" Metal Brake | [[user:zimmer62:start|Joe Zimmerman ]] | [[http://www.harborfreight.com/30-inch-bending-brake-67240.html|30 in. Bending Brake]] | [[zones:metalshop]] | |
- | | Router table | [[user:carlraymond:start|Carl Raymond]] | Homemade table with storage drawers; can make raised panel doors. Needs better fence | LMN - Woodshop | | + | |
- | | Wood Lathe | LMN | 5ft wood lathe | LMN - Woodshop | | + | |
- | | [[http://www.shopsmith.com/markvsite/|Shopsmith Mark 5]] | [[user:mflaga:start|Michael P. Flaga]] | 10" Table Saw, 34" Lathe, 6 1/2" Drill Press, 12" Disc Sander, Band saw, Shaper | LMN - Basement storage| | + | |
- | | Band Saw | LMN | Large free standing band saw | LMN - Woodshop | | + | |
| Band Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Band Saw | [[zones:parts storage]] | | | Band Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Band Saw | [[zones:parts storage]] | | ||
- | | Scroll Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Scroll Saw | LMN - Woodshop| | + | | Scroll Saw | [[user:zimmer62:start|Joe Zimmerman]] | Small Scroll Saw | [[zones:woodshop]]| |
- | | Brad Nailer | [[user:zimmer62:start|Joe Zimmerman]] | Pneumatic brad nail gun | LMN | | + | | Brad Nailer | [[user:zimmer62:start|Joe Zimmerman]] | Pneumatic brad nail gun | [[zones:woodshop]] | |
- | | Saw Dust collector/vacuum system | LMN | [[http://www.harborfreight.com/2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] | LMN - Woodshop| | + | | Saw Dust collector/vacuum system | LMN | [[http://www.harborfreight.com/2-hp-industrial-5-micron-dust-collector-97869.html|70 gal. Industrial 5 Micron Dust Collector]] | [[zones:woodshop]]| |
^ Electronics ^ ^ ^ ^ | ^ Electronics ^ ^ ^ ^ | ||
|Soldering iron|[[user:tim:start|Timothy Schmidt]]|Weller WES51| [[user:tim:start|Timothy Schmidt]] | | |Soldering iron|[[user:tim:start|Timothy Schmidt]]|Weller WES51| [[user:tim:start|Timothy Schmidt]] | | ||
|Solder sucker|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | |Solder sucker|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | ||
- | | Hot-air rework station | [[user:carlraymond:start|Carl Raymond]] | SparkFun 303D | LMN | | ||
|Helping hands|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | |Helping hands|[[user:tim:start|Timothy Schmidt]]| | [[user:tim:start|Timothy Schmidt]] | | ||
|Plextor PX-TV402U|[[user:tim:start|Timothy Schmidt]]|USB Hardware MPEG4 A/V input / analog TV tuner. Coaxial, RCA, and S-Video inputs| [[zones:parts storage]] | | |Plextor PX-TV402U|[[user:tim:start|Timothy Schmidt]]|USB Hardware MPEG4 A/V input / analog TV tuner. Coaxial, RCA, and S-Video inputs| [[zones:parts storage]] | | ||
^Communications^ ^ ^ ^ | ^Communications^ ^ ^ ^ | ||
Line 55: | Line 36: | ||
| Sand blaster | [[user:tim:start|Timothy Schmidt]] | [[http://www.harborfreight.com/40-lb-pressurized-abrasive-blaster-68992.html|40lb pressurized abrasive blaster]] -- requires very large air compressor | [[zones:parts storage]] | | | Sand blaster | [[user:tim:start|Timothy Schmidt]] | [[http://www.harborfreight.com/40-lb-pressurized-abrasive-blaster-68992.html|40lb pressurized abrasive blaster]] -- requires very large air compressor | [[zones:parts storage]] | | ||
- | | Sand blaster | LMN | [[http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P| Craftsman Sand Blaster]] | LMN | | + | | Sand blaster | LMN | [[http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P| Craftsman Sand Blaster]] | [[zones:parts storage]] | |
- | | Air Compressor | [[user:zimmer62:start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | LMN | | + | | Air Compressor | [[user:zimmer62:start|Joe Zimmerman]] | 30 Gallon Air Compressor + various tools | [[zones:woodshop]] | |
- | | 18 Volt Drill | LMN | Ryobi 18Volt drill | LMN - Woodshop | | + | | 18 Volt Drill | LMN | Ryobi 18Volt drill | [[zones:woodshop]] | |
- | | 18 Volt Impact Driver | LMN | Ryobi 18Volt impact driver | LMN - Woodshop | | + | | 18 Volt Impact Driver | LMN | Ryobi 18Volt impact driver | [[zones:woodshop]] | |
- | | Screw drivers | LMN | | LMN - Woodshop | | + | | Screw drivers | LMN | | [[zones:woodshop]] | |
- | | Wrenches | LMN | | LMN - Woodshop / Metalshop | | + | | Wrenches | LMN | | [[zones:woodshop]] / [[zones:metalshop]] | |
Line 68: | Line 49: | ||
