equipment:wishlist:laser_cutter [2015/08/14 16:27] wreality |
equipment:wishlist:laser_cutter [2015/08/18 13:35] zimmer62 |
Line 43: | Line 43: | ||
* How do we mix cutting and engraving? | * How do we mix cutting and engraving? | ||
* Will we also need to purchase AutoCAD or the like? | * Will we also need to purchase AutoCAD or the like? | ||
+ | - Keep in mind the weight and door size if we get a larger laser. | ||
Line 52: | Line 53: | ||
- | === Budget: === | + | === Budget: === |
- | * It was suggested that $1300 could be paid for by LMN (gut feeling from Carl) | + | * $2500, of which 50% needs to be raised in new donations. |
- | * Other possible donations could get an additional $1100 fairly easily. | + | * Any funds raised in excess of the 50% match will increase the Equipment Purchase line item, for the purpose of purchasing the laser. |
+ | === Fund Raising: === | ||
+ | * FIXME Ideas are needed here | ||
