equipment:wishlist:laser_cutter [2015/08/05 19:44] zimmer62 |
equipment:wishlist:laser_cutter [2015/10/05 12:57] zimmer62 |
+ | ==== Status: ==== | ||
+ | Laser cutter has been purchased and delivered. **The information below is for archive purposes** | ||
======= New Laser Cutter Working Group ======= | ======= New Laser Cutter Working Group ======= | ||
Line 5: | Line 8: | ||
=== Working Group Members: === | === Working Group Members: === | ||
* [[user:zimmer62:start|Joe Zimmerman]] | * [[user:zimmer62:start|Joe Zimmerman]] | ||
+ | * [[user:zik:start|Ed Symanzik]] | ||
+ | * [[user:wreality:start|Brian Adams]] | ||
Line 22: | Line 29: | ||
* The new laser cutter should be able to be shipped to LMN within a reasonable time frame | * The new laser cutter should be able to be shipped to LMN within a reasonable time frame | ||
+ | * Fibre lasers do not cut wood: http://www.engraversjournal.com/article.php/2743/index.html | ||
Line 34: | Line 41: | ||
* Power | * Power | ||
* Venting | * Venting | ||
+ | - What can we expect for support? | ||
+ | * Will it be supported by an ebay distributor? | ||
+ | * Will we need a Chinese speaker? | ||
+ | - What software will we need? | ||
+ | * Some of these cutters list several supported graphics formats but not gcode. | ||
+ | * How do we mix cutting and engraving? | ||
+ | * Will we also need to purchase AutoCAD or the like? | ||
+ | - Keep in mind the weight and door size if we get a larger laser. | ||
Line 41: | Line 56: | ||
* Do any of these have forum followings such as the K40 does? | * Do any of these have forum followings such as the K40 does? | ||
- | === Budget: === | + | === Budget: === |
- | * It was suggested that $1300 could be paid for by LMN (gut feeling from Carl) | + | * $2500, of which 50% needs to be raised in new donations. |
- | * Other possible donations could get an additional $1100 fairly easily. | + | * Any funds raised in excess of the 50% match will increase the Equipment Purchase line item, for the purpose of purchasing the laser. |
+ | === Fund Raising: === | ||
+ | * FIXME Ideas are needed here | ||
=== Links: === | === Links: === | ||
* http://www.ebay.com/itm/110V-60W-USB-Laser-Engraving-Cutting-Machine-Laser-Engraver-Cutter-CE-FDA-/161688742870?hash=item25a5666bd6 | * http://www.ebay.com/itm/110V-60W-USB-Laser-Engraving-Cutting-Machine-Laser-Engraver-Cutter-CE-FDA-/161688742870?hash=item25a5666bd6 | ||
=== To Do: === | === To Do: === | ||
* Create a Grid on this wiki with links, prices, wattage, cutting size, and additional notes. | * Create a Grid on this wiki with links, prices, wattage, cutting size, and additional notes. |
