equipment:uscutter_lp_24 [2014/05/14 04:18]
wreality created
equipment:uscutter_lp_24 [2016/01/28 18:03]
wreality Changed owner. Tool was donated.
 +~~NOTOC~~
 ---- datatemplateentry equipment ---- ---- datatemplateentry equipment ----
 template ​     : templates:​equipment template ​     : templates:​equipment
 picture ​      : :​equipment:​uscutter:​uscutter-lp-24.jpg picture ​      : :​equipment:​uscutter:​uscutter-lp-24.jpg
-zone          : Crafting+zone          : Laser
 name          : 24in Vinyl Cutter name          : 24in Vinyl Cutter
 manufacturer ​ : US Cutter manufacturer ​ : US Cutter
Line 8: Line 10:
 manual ​       : :​equipment:​uscutter:​laserpoint_manual.pdf manual ​       : :​equipment:​uscutter:​laserpoint_manual.pdf
 memberlevel ​  : Coder/​Crafter memberlevel ​  : Coder/​Crafter
-owner         : ​Xarrax Lee+owner         : ​LMN
 type          : Vinyl Cutter type          : Vinyl Cutter
 status_ ​      : Operational status_ ​      : Operational
Line 15: Line 17:
 +Makes really big and or small stickers
 ===Contacts for training== ===Contacts for training==
-  * Rose Canino-King+  * Rose Canino-Koning
   * Brian Adams   * Brian Adams
   * Nick Kwiatkowski   * Nick Kwiatkowski
   * Joe Zimmerman   * Joe Zimmerman
-===Maintenance ​Log===+==== Specifications ====
 +24 in wide cutter
 +==== Workflow ====
 +  - import vector drawing
 +  - ensure the image is a vector.
 +    - If not see manuals section "​Converting a Raster Image to Vector Image"​
 +  - select cut
 +  - select cut
 +  - select finish
 +==== Software & Drivers ====
 +In short...
 +Install "​SignBlazer Elements for USCutter"​
 +The interface to the LaserPoint24 is Serial. The LP24 has both a DB9 or USB. Where the USB will install as a FDTI and should auto install. If needed drivers are available at http://​support.uscutter.com/​index.php?/​Knowledgebase/​List/​Index/​39
 +SignBlazer is a free design and cutting utility for Windows O/S only. It suits the needs of many customers but lacks much of the power and functionality of true design programs such as,​CorelDraw or Inkscape (inkscape.org). The official release of SignBlazer only works in "Trial Mode" ​ but it is fully functional. It also does not require an activation code of any kind; nor do you need to register or update it because it is no longer being developed.
 +http://​support.uscutter.com/​index.php?/​Knowledgebase/​Article/​View/​190/​27/​01-signblazer-elements
 +==== Consumables ====
 +  * Rolls of vinyl
 +  * Transfer Tape
 +==== Tutorials ====
 +Please read the following sections of the manual, they are quite short and straight forward.
 +  * "​Selecting a Location for Your Cutter"​
 +  * "​Starting SignBlazer"​
 +==== Maintenance ===
 +Please roll and store leftover vinyl, and dispose of vinyl pickings. ​ The cutting blade muat be replaced periodically. ​ Xarrax says the $5 ebay blades broke less often and cut longer than the expensive ones in this machine.
 +==== Resources ====
 +http://​support.uscutter.com/​index.php?/​Knowledgebase/​List/​Index/​61/​laserpoint
