equipment:makerfarm-i3 [2015/08/29 03:04]
mflaga
equipment:makerfarm-i3 [2017/04/05 00:38] (current)
 ---- datatemplateentry equipment ---- ---- datatemplateentry equipment ----
 template ​     : templates:​equipment template ​     : templates:​equipment
-picture ​      : :​equipment:​makerfarm-i3:​makerfarm_v1.jpg+picture ​      : :​equipment:​makerfarm-i3:​img_7841.jpg
 zone          : 3D Printing zone          : 3D Printing
 name          : Makerfarm Prusa i3 3d Printer name          : Makerfarm Prusa i3 3d Printer
Line 35: Line 35:
         * changed default user/pw of R-Pi.         * changed default user/pw of R-Pi.
         * set timezone         * set timezone
 +        * set keyboard to PC104-US
         * Network setup with static IP at 10.1.10.221,​ on WiFi         * Network setup with static IP at 10.1.10.221,​ on WiFi
           * Note, seems OctoPi has FUBAR'​ed wlan0 auto setup.           * Note, seems OctoPi has FUBAR'​ed wlan0 auto setup.
Line 44: Line 45:
           * There is no DNS at the space, yet.           * There is no DNS at the space, yet.
           * ComCast is DHCP, and there is no DynDNS setup. So you just need to know. It does not change much.           * ComCast is DHCP, and there is no DynDNS setup. So you just need to know. It does not change much.
-      * Pi camera has been ordered. Currently is trying Pi-Cam, very slow.
-        * Need to investigate slowing down the FPS. Too much for Pi FFMPEG
       * Octo-Pi has been installed, ​       * Octo-Pi has been installed, ​
         * created users         * created users
Line 56: Line 55:
         * Changed Web Page Host name to "LMN MakerFarm i3 Prues"         * Changed Web Page Host name to "LMN MakerFarm i3 Prues"
         * Limited haproxy to maxconn of 2. only lets two web pages, as not to overload Pi.         * Limited haproxy to maxconn of 2. only lets two web pages, as not to overload Pi.
 +      * USB camera has been ordered. ​
 +        * Currently is trying Pi-Cam, very slow.
 +      * Printer setup modified for
 +        * temperatures
 +        * beginning and ending Gcode scripts ​
 +        * auto bed leveling code
 +      * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface
 +      * Added the following plugins
 +        * Custom Control Editor
 +        * System Command Editor
 +        * Editor Collection
 +        * EEPROM Marlin Editor
 +        * Print History
 +        * STL Viewer
 +      * Added stub commands to control the lighting
 +        * Currently using M42 P4 S255 / M42 P4 S0  ​
 +          * We still need a relay hooked up to this pin to drive a light.
     * Still needs done:     * Still needs done:
       * 3D Print an enclosure for the pi       * 3D Print an enclosure for the pi
         * currently using a stock case. But a better custom case to attach to MakerFarm is desired.         * currently using a stock case. But a better custom case to attach to MakerFarm is desired.
-      * Create a printer profile+      * Need to investigate slowing down the FPS. Too much for Pi FFMPEG
 +      * More ...
       * Write instructions on how to connect and print       * Write instructions on how to connect and print
       * Install and test Cura profiles so STL's can be sliced on the machine       * Install and test Cura profiles so STL's can be sliced on the machine
 +          * Test Raspberry Pi B for slicing - may be a problem for larger or complicated parts
 +          * If too slow, slice before uploading or consider Raspberry Pi2
       * Install Pi camera on machine which might include 3d printing an enclosure for the camera.       * Install Pi camera on machine which might include 3d printing an enclosure for the camera.
-          ​* Currently Duct tape and Wire is holding camera. ​+        ​* Currently Duct tape and Wire is holding camera
 +      * Add LED/Lamp for Camera
 +        * Drive it from Ramps either:
 +          * Using an M42 G-code and the octoprint command plug in creating a couple buttons should be easy
 +            * http://​neverstopbuilding.com/​bed-lighting
 +            * http://​plugins.octoprint.org/​plugins/​customControl/​
 +          * Other ideas include:
 +            * in parallel to fans
 +            * in parallel to Motors being energized
 +      * Consider all possible scenarios for overheating or loss of control
 +      * Address the issue of the PSU load which is not connected well and also may overheat nearby objects
 +      * A backup of the SD card should be done, and some sort of regular backup system should be in place so if something is ever broken we have a place in time to restore to.
     * Considerations:​     * Considerations:​
       * LDAP authentication or equivalent for future https://​github.com/​foosel/​OctoPrint/​issues/​594       * LDAP authentication or equivalent for future https://​github.com/​foosel/​OctoPrint/​issues/​594
