equipment:makerfarm-i3 [2014/05/29 18:42]
tim
equipment:makerfarm-i3 [2017/04/05 00:38] (current)
 ---- datatemplateentry equipment ---- ---- datatemplateentry equipment ----
 template ​     : templates:​equipment template ​     : templates:​equipment
-picture ​      : :​equipment:​makerfarm-i3:​makerfarm_v1.jpg+picture ​      : :​equipment:​makerfarm-i3:​img_7841.jpg
 zone          : 3D Printing zone          : 3D Printing
 name          : Makerfarm Prusa i3 3d Printer name          : Makerfarm Prusa i3 3d Printer
Line 8: Line 8:
 manual ​       : :​equipment:​makerfarm-i3:​laser_cut_i3_v2_8_inch.pdf manual ​       : :​equipment:​makerfarm-i3:​laser_cut_i3_v2_8_inch.pdf
 memberlevel ​  : Coder/​Crafter memberlevel ​  : Coder/​Crafter
-owner         : ​Craig Pontius+owner         : ​LMN
 type          : 3D Printer type          : 3D Printer
 status_ ​      : Operational status_ ​      : Operational
Line 15: Line 15:
 +Makerfarm 3d printer donated by Craig Pontius
 +===Firmware===
 +https://​github.com/​timschmidt/​lmn-makerfarm
 ===Contacts for training== ===Contacts for training==
Line 20: Line 23:
   * Joe Zimmerman   * Joe Zimmerman
   * Tim Schmidt   * Tim Schmidt
 +  * Jerry Fahner
 ===Maintenance Log=== ===Maintenance Log===
 +===Future Enhancements===
 +  * Octoprint:
 +    * Already done:
 +      * RaspberryPi-B,​ USB wifi adaptor, SD card have been gathered and at MakerFarm
 +        * apt-get, rasp-config and OctoPrint upgrades have been done.
 +        * changed default user/pw of R-Pi.
 +        * set timezone
 +        * set keyboard to PC104-US
 +        * Network setup with static IP at 10.1.10.221,​ on WiFi
 +          * Note, seems OctoPi has FUBAR'​ed wlan0 auto setup.
 +      * Setup Port foward for below on ComCast Router.
 +        * 22180->​80(HTTP)
 +        * 22144->​443(HTTPS)
 +        * 22122->​22(SSH)
 +        * Note
 +          * There is no DNS at the space, yet.
 +          * ComCast is DHCP, and there is no DynDNS setup. So you just need to know. It does not change much.
 +      * Octo-Pi has been installed, ​
 +        * created users
 +          * some Octo Admin'​s
 +          * a LMN common user
 +        * enabled Auto login by local network
 +          * any internal 10.1.10.0/​24 will auto login with access. ​
 +          * Remote or outside will be view only, unless with user/pw.
 +        * enabled auto connect
 +        * Changed Web Page Host name to "LMN MakerFarm i3 Prues"
 +        * Limited haproxy to maxconn of 2. only lets two web pages, as not to overload Pi.
 +      * USB camera has been ordered. ​
 +        * Currently is trying Pi-Cam, very slow.
 +      * Printer setup modified for
 +        * temperatures
 +        * beginning and ending Gcode scripts ​
 +        * auto bed leveling code
 +      * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface
 +      * Added the following plugins
 +        * Custom Control Editor
 +        * System Command Editor
 +        * Editor Collection
 +        * EEPROM Marlin Editor
 +        * Print History
 +        * STL Viewer
 +      * Added stub commands to control the lighting
 +        * Currently using M42 P4 S255 / M42 P4 S0  ​
 +          * We still need a relay hooked up to this pin to drive a light.
 +    * Still needs done:
 +      * 3D Print an enclosure for the pi
 +        * currently using a stock case. But a better custom case to attach to MakerFarm is desired.
 +      * Need to investigate slowing down the FPS. Too much for Pi FFMPEG
 +      * More ...
 +      * Write instructions on how to connect and print
 +      * Install and test Cura profiles so STL's can be sliced on the machine
 +          * Test Raspberry Pi B for slicing - may be a problem for larger or complicated parts
 +          * If too slow, slice before uploading or consider Raspberry Pi2
 +      * Install Pi camera on machine which might include 3d printing an enclosure for the camera.
 +        * Currently Duct tape and Wire is holding camera.
 +      * Add LED/Lamp for Camera
 +        * Drive it from Ramps either:
 +          * Using an M42 G-code and the octoprint command plug in creating a couple buttons should be easy
 +            * http://​neverstopbuilding.com/​bed-lighting
 +            * http://​plugins.octoprint.org/​plugins/​customControl/​
 +          * Other ideas include:
 +            * in parallel to fans
 +            * in parallel to Motors being energized
 +      * Consider all possible scenarios for overheating or loss of control
 +      * Address the issue of the PSU load which is not connected well and also may overheat nearby objects
 +      * A backup of the SD card should be done, and some sort of regular backup system should be in place so if something is ever broken we have a place in time to restore to.
 +    * Considerations:​
 +      * LDAP authentication or equivalent for future https://​github.com/​foosel/​OctoPrint/​issues/​594
