equipment:makerfarm-i3 [2015/09/01 19:18] zimmer62 |
equipment:makerfarm-i3 [2015/09/08 18:01] zimmer62 |
Line 62: | Line 62: | ||
* auto bed leveling code | * auto bed leveling code | ||
* OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface | * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface | ||
+ | * Editor Collection | ||
+ | * Print History | ||
+ | * STL Viewer | ||
Line 81: | Line 91: | ||
* in parallel to fans | * in parallel to fans | ||
* in parallel to Motors being energized | * in parallel to Motors being energized | ||
* Address the issue of the PSU load which is not connected well and also may overheat nearby objects | * Address the issue of the PSU load which is not connected well and also may overheat nearby objects |
