equipment:makerfarm-i3 [2015/08/31 13:22] zimmer62 |
equipment:makerfarm-i3 [2015/09/08 18:01] zimmer62 |
Line 61: | Line 61: | ||
* beginning and ending Gcode scripts | * beginning and ending Gcode scripts | ||
* auto bed leveling code | * auto bed leveling code | ||
+ | * Editor Collection | ||
+ | * Print History | ||
+ | * STL Viewer | ||
Line 80: | Line 91: | ||
* in parallel to fans | * in parallel to fans | ||
* in parallel to Motors being energized | * in parallel to Motors being energized | ||
* Address the issue of the PSU load which is not connected well and also may overheat nearby objects | * Address the issue of the PSU load which is not connected well and also may overheat nearby objects | ||
