equipment:makerfarm-i3 [2015/08/29 16:15] jfahner3 |
equipment:makerfarm-i3 [2015/09/08 18:01] zimmer62 |
Line 61: | Line 61: | ||
* beginning and ending Gcode scripts | * beginning and ending Gcode scripts | ||
* auto bed leveling code | * auto bed leveling code | ||
+ | * Editor Collection | ||
+ | * Print History | ||
+ | * STL Viewer | ||
Line 74: | Line 85: | ||
* Add LED/Lamp for Camera | * Add LED/Lamp for Camera | ||
* Drive it from Ramps either: | * Drive it from Ramps either: | ||
- | * in parallel to fans | + | * Using an M42 G-code and the octoprint command plug in creating a couple buttons should be easy |
- | * in parallel to Motors being energized | + | * http://neverstopbuilding.com/bed-lighting |
- | * Add a G-Code (there may already be one) and create OctoPrint Plug-In | + | * http://plugins.octoprint.org/plugins/customControl/ |
* Address the issue of the PSU load which is not connected well and also may overheat nearby objects | * Address the issue of the PSU load which is not connected well and also may overheat nearby objects | ||
