equipment:makerfarm-i3 [2015/09/01 19:21] zimmer62 |
equipment:makerfarm-i3 [2017/04/05 00:38] |
- | picture : :equipment:makerfarm-i3:makerfarm_v1.jpg | ||
- | zone : 3D Printing | ||
- | name : Makerfarm Prusa i3 3d Printer | ||
- | manufacturer : Makerfarm | ||
- | model : i3 | ||
- | manual : :equipment:makerfarm-i3:laser_cut_i3_v2_8_inch.pdf | ||
- | memberlevel : Coder/Crafter | ||
- | owner : LMN | ||
- | type : 3D Printer | ||
- | ===Description=== | ||
- | Makerfarm 3d printer donated by Craig Pontius | ||
- | ===Firmware=== | ||
- | https://github.com/timschmidt/lmn-makerfarm | ||
- | * Carl Raymond | ||
- | * Joe Zimmerman | ||
- | * Tim Schmidt | ||
- | * Jerry Fahner | ||
- | ===Maintenance Log=== | ||
- | ===Future Enhancements=== | ||
- | * Octoprint: | ||
- | * Already done: | ||
- | * RaspberryPi-B, USB wifi adaptor, SD card have been gathered and at MakerFarm | ||
- | * apt-get, rasp-config and OctoPrint upgrades have been done. | ||
- | * changed default user/pw of R-Pi. | ||
- | * set timezone | ||
- | * set keyboard to PC104-US | ||
- | * Network setup with static IP at 10.1.10.221, on WiFi | ||
- | * Note, seems OctoPi has FUBAR'ed wlan0 auto setup. | ||
- | * Setup Port foward for below on ComCast Router. | ||
- | * 22180->80(HTTP) | ||
- | * 22144->443(HTTPS) | ||
- | * 22122->22(SSH) | ||
- | * Note | ||
- | * There is no DNS at the space, yet. | ||
- | * ComCast is DHCP, and there is no DynDNS setup. So you just need to know. It does not change much. | ||
- | * Octo-Pi has been installed, | ||
- | * created users | ||
- | * some Octo Admin's | ||
- | * a LMN common user | ||
- | * enabled Auto login by local network | ||
- | * any internal 10.1.10.0/24 will auto login with access. | ||
- | * Remote or outside will be view only, unless with user/pw. | ||
- | * enabled auto connect | ||
- | * Changed Web Page Host name to "LMN MakerFarm i3 Prues" | ||
- | * Limited haproxy to maxconn of 2. only lets two web pages, as not to overload Pi. | ||
- | * USB camera has been ordered. | ||
- | * Currently is trying Pi-Cam, very slow. | ||
- | * Printer setup modified for | ||
- | * temperatures | ||
- | * beginning and ending Gcode scripts | ||
- | * auto bed leveling code | ||
- | * OctoPrint has been updated from 1.2.4 to 1.2.5(stable) using the interface | ||
- | * Still needs done: | ||
- | * 3D Print an enclosure for the pi | ||
- | * currently using a stock case. But a better custom case to attach to MakerFarm is desired. | ||
- | * Need to investigate slowing down the FPS. Too much for Pi FFMPEG | ||
- | * More ... | ||
- | * Write instructions on how to connect and print | ||
- | * Install and test Cura profiles so STL's can be sliced on the machine | ||
- | * Test Raspberry Pi B for slicing - may be a problem for larger or complicated parts | ||
- | * If too slow, slice before uploading or consider Raspberry Pi2 | ||
- | * Install Pi camera on machine which might include 3d printing an enclosure for the camera. | ||
- | * Currently Duct tape and Wire is holding camera. | ||
- | * Add LED/Lamp for Camera | ||
- | * Drive it from Ramps either: | ||
- | * Using an M42 G-code and the octoprint command plug in creating a couple buttons should be easy | ||
- | * http://neverstopbuilding.com/bed-lighting | ||
- | * http://plugins.octoprint.org/plugins/customControl/ | ||
- | * Other ideas include: | ||
- | * in parallel to fans | ||
- | * in parallel to Motors being energized | ||
- | * Consider all possible scenarios for overheating or loss of control | ||
- | * Address the issue of the PSU load which is not connected well and also may overheat nearby objects | ||
- | * A backup of the SD card should be done, and some sort of regular backup system should be in place so if something is ever broken we have a place in time to restore to. | ||
- | * Considerations: | ||
- | * LDAP authentication or equivalent for future https://github.com/foosel/OctoPrint/issues/594 |
