equipment:makerfarm-i3 [2015/08/29 03:04] mflaga |
equipment:makerfarm-i3 [2015/08/31 13:22] zimmer62 |
Line 35: | Line 35: | ||
* changed default user/pw of R-Pi. | * changed default user/pw of R-Pi. | ||
* set timezone | * set timezone | ||
* Network setup with static IP at 10.1.10.221, on WiFi | * Network setup with static IP at 10.1.10.221, on WiFi | ||
* Note, seems OctoPi has FUBAR'ed wlan0 auto setup. | * Note, seems OctoPi has FUBAR'ed wlan0 auto setup. | ||
Line 44: | Line 45: | ||
* There is no DNS at the space, yet. | * There is no DNS at the space, yet. | ||
* ComCast is DHCP, and there is no DynDNS setup. So you just need to know. It does not change much. | * ComCast is DHCP, and there is no DynDNS setup. So you just need to know. It does not change much. | ||
- | * Pi camera has been ordered. Currently is trying Pi-Cam, very slow. | ||
- | * Need to investigate slowing down the FPS. Too much for Pi FFMPEG | ||
* Octo-Pi has been installed, | * Octo-Pi has been installed, | ||
* created users | * created users | ||
Line 56: | Line 55: | ||
* Changed Web Page Host name to "LMN MakerFarm i3 Prues" | * Changed Web Page Host name to "LMN MakerFarm i3 Prues" | ||
* Limited haproxy to maxconn of 2. only lets two web pages, as not to overload Pi. | * Limited haproxy to maxconn of 2. only lets two web pages, as not to overload Pi. | ||
+ | * temperatures | ||
* currently using a stock case. But a better custom case to attach to MakerFarm is desired. | * currently using a stock case. But a better custom case to attach to MakerFarm is desired. | ||
- | * Create a printer profile | + | * Need to investigate slowing down the FPS. Too much for Pi FFMPEG |
+ | * More ... | ||
- | * Currently Duct tape and Wire is holding camera. | + | * Currently Duct tape and Wire is holding camera. |
