equipment:makerfarm-i3 [2015/08/27 12:56] zimmer62 |
equipment:makerfarm-i3 [2015/09/01 19:18] zimmer62 |
Line 31: | Line 31: | ||
* Octoprint: | * Octoprint: | ||
* Already done: | * Already done: | ||
- | * RaspberryPi, USB wifi adaptor, SD card have been gathered. | + | * RaspberryPi-B, USB wifi adaptor, SD card have been gathered and at MakerFarm |
- | * Octo-Pi has been installed. | + | * apt-get, rasp-config and OctoPrint upgrades have been done. |
- | * Networking | + | * changed default user/pw of R-Pi. |
- | * Pi camera has been ordered | + | * set timezone |
+ | * 22180->80(HTTP) | ||
+ | * 22144->443(HTTPS) | ||
+ | * 22122->22(SSH) | ||
+ | * Note | ||
+ | * created users | ||
+ | * some Octo Admin's | ||
+ | * a LMN common user | ||
+ | * temperatures | ||
- | * Setup network with static IP or DNS at the space | ||
- | * Create a printer profile | + | * currently using a stock case. But a better custom case to attach to MakerFarm is desired. |
- | * Add LMN account so people may use this to print | + | * Need to investigate slowing down the FPS. Too much for Pi FFMPEG |
+ | * More ... | ||
- | * Considerations: | + | * Currently Duct tape and Wire is holding camera. |
- | * Publicly accessible IP? or VPN or Proxy, so that you can connect to this device from outside the space. | + | * Add LED/Lamp for Camera |
- | * If you can connect from outside the space we need to ensure we don't have tons of users connecting at once. Quite possibility a limited number of connections, and must require a user account to access this device. | + | * Drive it from Ramps either: |
- | * https://github.com/foosel/OctoPrint/issues/594 | + | * Using an M42 G-code and the octoprint command plug in creating a couple buttons should be easy |
- | * | + | * http://neverstopbuilding.com/bed-lighting |
+ | * Considerations: | ||
