equipment:makerfarm-i3 [2015/08/26 13:46] zimmer62 |
equipment:makerfarm-i3 [2015/08/27 12:56] zimmer62 |
manual : :equipment:makerfarm-i3:laser_cut_i3_v2_8_inch.pdf | manual : :equipment:makerfarm-i3:laser_cut_i3_v2_8_inch.pdf | ||
memberlevel : Coder/Crafter | memberlevel : Coder/Crafter | ||
- | owner : Craig Pontius | + | owner : LMN |
type : 3D Printer | type : 3D Printer | ||
Line 15: | Line 15: | ||
+ | Makerfarm 3d printer donated by Craig Pontius | ||
===Firmware=== | ===Firmware=== | ||
https://github.com/timschmidt/lmn-makerfarm | https://github.com/timschmidt/lmn-makerfarm | ||
Line 43: | Line 43: | ||
+ | * Considerations: | ||
+ | * Publicly accessible IP? or VPN or Proxy, so that you can connect to this device from outside the space. | ||
+ | * If you can connect from outside the space we need to ensure we don't have tons of users connecting at once. Quite possibility a limited number of connections, and must require a user account to access this device. | ||
+ | * https://github.com/foosel/OctoPrint/issues/594 | ||
