equipment:makerfarm-i3 [2014/05/14 04:58] wreality created |
equipment:makerfarm-i3 [2015/09/01 19:21] zimmer62 |
manual : :equipment:makerfarm-i3:laser_cut_i3_v2_8_inch.pdf | manual : :equipment:makerfarm-i3:laser_cut_i3_v2_8_inch.pdf | ||
memberlevel : Coder/Crafter | memberlevel : Coder/Crafter | ||
- | owner : | + | owner : LMN |
type : 3D Printer | type : 3D Printer | ||
Line 15: | Line 15: | ||
+ | Makerfarm 3d printer donated by Craig Pontius | ||
+ | ===Firmware=== | ||
+ | https://github.com/timschmidt/lmn-makerfarm | ||
Line 20: | Line 23: | ||
* Joe Zimmerman | * Joe Zimmerman | ||
* Tim Schmidt | * Tim Schmidt | ||
+ | * Jerry Fahner | ||
===Maintenance Log=== | ===Maintenance Log=== | ||
+ | ===Future Enhancements=== | ||
+ | * Octoprint: | ||
+ | * Already done: | ||
+ | * RaspberryPi-B, USB wifi adaptor, SD card have been gathered and at MakerFarm | ||
+ | * apt-get, rasp-config and OctoPrint upgrades have been done. | ||
+ | * changed default user/pw of R-Pi. | ||
+ | * set timezone | ||
+ | * 22180->80(HTTP) | ||
+ | * 22144->443(HTTPS) | ||
+ | * 22122->22(SSH) | ||
+ | * Note | ||
+ | * created users | ||
+ | * some Octo Admin's | ||
+ | * a LMN common user | ||
+ | * temperatures | ||
+ | * Still needs done: | ||
+ | * 3D Print an enclosure for the pi | ||
+ | * currently using a stock case. But a better custom case to attach to MakerFarm is desired. | ||
+ | * Need to investigate slowing down the FPS. Too much for Pi FFMPEG | ||
+ | * More ... | ||
+ | * Write instructions on how to connect and print | ||
+ | * Install and test Cura profiles so STL's can be sliced on the machine | ||
+ | * Install Pi camera on machine which might include 3d printing an enclosure for the camera. | ||
+ | * Considerations: | ||
