equipment:kh7050b-laser_cutter [2016/02/09 16:41] wreality |
Line 11: | Line 11: | ||
- | sops_url : https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing | + | sop : https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing |
- | checkout_required : Yes | + | checkout : Yes |
Line 37: | Line 37: | ||
Line 53: | Line 56: | ||
