equipment:kh7050b-laser_cutter [2016/01/28 18:00] wreality |
Line 11: | Line 11: | ||
+ | sop : https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing | ||
+ | checkout : Yes | ||
Line 27: | Line 29: | ||
- | * In Addition to the [[zones:shop safety rules]] the following safety rules should be followed: | ||
* [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | * [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | ||
Line 34: | Line 35: | ||
* 2015-10-04 limit switch shimmed | * 2015-10-04 limit switch shimmed | ||
* 2015-10-03 E-stop switch replaced after being broken | * 2015-10-03 E-stop switch replaced after being broken | ||
+ | * 2015-12-?? E-stop switch replaced after shorting closed | ||
+ | * 2016-01-18 E-stop switch replaced after melted contact | ||
+ | * 2016-01-?? Power switch replaced with rotary switch similar to what the machine shipped with | ||
+ | * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window. | ||
Line 48: | Line 56: | ||
