equipment:kh7050b-laser_cutter [2016/03/26 22:50] wreality added maint itemes |
equipment:kh7050b-laser_cutter [2017/06/26 23:41] wreality |
Line 31: | Line 31: | ||
* [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | * [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | ||
- | ===Maintenance Log== | + | ===Maintenance Log=== |
* 2015-10-05 mounted exhaust fan to wall | * 2015-10-05 mounted exhaust fan to wall | ||
* 2015-10-04 limit switch shimmed | * 2015-10-04 limit switch shimmed | ||
Line 37: | Line 37: | ||
- | * 2016-03-26 Cleaned lens, head mirror, and gantry mirror. Adjusted/checked focus. | + | * 2016-03-26 Cleaned lens, head mirror, and gantry mirror. Adjusted/checked alignment. |
=== Gallery === | === Gallery === |
