equipment:kh7050b-laser_cutter [2016/02/09 16:32]
wreality
equipment:kh7050b-laser_cutter [2017/06/26 23:41]
wreality
Line 11: Line 11:
 type          : Laser Cutter # Generic name of the tool (Table Saw vs. 10" Contractor Table Saw) type          : Laser Cutter # Generic name of the tool (Table Saw vs. 10" Contractor Table Saw)
 status_ ​      : Operational # Operational || Needs Repair || Needs Documentation || etc status_ ​      : Operational # Operational || Needs Repair || Needs Documentation || etc
-SOPs          ​[[https://​drive.google.com/​folderview?​id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&​usp=sharing|Laser Cutter SOPs]] +sop           : https://​drive.google.com/​folderview?​id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&​usp=sharing
-checkout_required ​: Yes+checkout ​: Yes
Line 37: Line 37:
   * 2015-12-?? E-stop switch replaced after shorting closed   * 2015-12-?? E-stop switch replaced after shorting closed
   * 2016-01-18 E-stop switch replaced after melted contact   * 2016-01-18 E-stop switch replaced after melted contact
-  * 2016-01-?? ​E-stop ​switch replaced with rotary switch similar to what the machine shipped with+  * 2016-01-?? ​Power switch replaced with rotary switch similar to what the machine shipped with
   * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window.   * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window.
 +  * 2016-03-26 Cleaned lens, head mirror, and gantry mirror. ​ Adjusted/​checked alignment.
 +  * 2016-10-27 Flourescent worklight tube replace. (22in T5 14W) -- B.Adams
 +  * 2017-06-26 Lenses and mirrors cleaned (all) -- B. Adams
 === Gallery === === Gallery ===
Line 53: Line 56:
 === Links === === Links ===
-  * [[http://​www.cnczone.com/​forums/​general-laser-engraving-cutting-machine-discussion/​259480-software-forum-3.html|Usefull ​forum]]+  * [[http://​www.cnczone.com/​forums/​general-laser-engraving-cutting-machine-discussion/​259480-software-forum-3.html|Useful ​forum]]
   * [[http://​www.thunderlaser.com/​how-to-use-laser-software|How to use software videos]]   * [[http://​www.thunderlaser.com/​how-to-use-laser-software|How to use software videos]]
