Both sides previous revision Previous revision Next revision | Previous revision Last revision Both sides next revision | ||
equipment:kh7050b-laser_cutter [2016/01/28 22:08] zimmer62 |
equipment:kh7050b-laser_cutter [2017/04/05 00:38] 127.0.0.1 external edit |
Line 11: | Line 11: | ||
+ | sop : https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing | ||
+ | checkout : Yes | ||
Line 27: | Line 29: | ||
- | * In Addition to the [[zones:shop safety rules]] the following safety rules should be followed: | ||
* [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | * [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | ||
Line 36: | Line 37: | ||
Line 52: | Line 55: | ||
